Good morning,
I hope everyone is staying safe during these very unusual times.
I’m currently in the planning stages of setting up a DIY battery backup system at home using a couple AGM 12V Deep Cycle batteries, and a 2,000 watt pure sine inverter. Eventually the system will be recharged by solar, but I’m just not there yet.
In the interim, if there were to be an emergency, I’d like the ability to charge these two AGM batteries using the Kona EV. I have a highly recommended smart charger that requires 172 watts to operate…The GENIUS10 requires 120-240 VAC, 50-60 Hz, and 172-watts to operate.
Does anyone see any issues with me placing my Kona EV in Utility Mode, and with the aid of an inverter, using this battery charger via the Kona’s 12v cigarette lighter port?
If the recommendation here is to avoid the cigarette lighter port and work directly from the Kona’s 12V starter battery, should I avoid placing the Kona in Utility Mode?
I definitely want to ensure that the 12V battery is being maintained properly by the Kona’s internal systems.
Thanks,
Fred
Thanks,
Fred
