I was able keep every thing 120 volt running with out having to listen to the generator drone on all day and night and suck my propane tank dry. Disadvantage to this set up is that I have individually plug things in to the inverter (with a power strip).
Thanks for filling us in, Fastnf. I wonder, would a transfer switch be a reasonable upgrade to your current setup? That way you can skip the extension cords/strips abuse and still be able to power a bunch of 120V circuits.
The DC to DC converter will put or around 1200 watts from Large battery. Usage above that will start to draw down the 12 volt battery. I have read that usage above 1500 watts will blow a fuse on the Kona.
the LDC fuse is 150 amps and that's where all the power comes from at approx 14.5 V in utility mode. One approach is that at 80% of that fuse rating on a continuous basis is 1740 watts.
So I'm trying to make sense of these statements. If the LDC unit is limited to supplying 1200W, then in what scenario would cause it to operate in the 1500W to 1740W+ danger zone? Might a large surge on the 12V battery have anything to do with it?
