That's the Dr. Jekyll and Mr. Hyde personality of the Clarity that's caused the car to be misunderstood, sometimes resulting in bad reviews. If you hold a significant charge in the high voltage battery, the car is an excellent performer in either EV or HV mode. Once the battery is depleted, it can run adequately in most circumstances but it is very power limited resulting in a very unsatisfying and potentially dangerous experience when you need power. Here, the car relies almost entirely on the ICE to generate electricity to power the traction motor to avoid drawing from what's left of the battery, protecting it from damage. Note that the Honda Accord Hybrid has a much bigger, more powerful ICE to generate electricity to its otherwise identical drive system even though the car is nearly 700 lbs lighter than the Clarity. Why? Because it has a Li ion battery a tenth the size of the Clarity, which cannot provide much power on its own. That Honda installed a much smaller ICE in the much heavier Clarity says that it is not meant to be driven with a depleted battery, because you won't receive the full performance of the drive system. I don't know how much power you have relying entirely on ICE/generator but it's likely to be significantly less than the peak 103 horsepower that the ICE can produce near the redline (i.e., if it is screaming), possibly only 61 hp (battery alone can produce 120 hp; battery + ICE produces max 181 hp). Just think about it. Driving a 4,054 lb car with less power than the minuscule two seater Smart Car puts out. It's no wonder why some reviews have been terrible. They were driving the Clarity with a depleted battery. You should avoid driving the Clarity with a depleted battery if at all possible. It could even be dangerous in emergency situations. In addition, HV mileage seems to be much better if you keep a major charge in the battery so it's better for the environment and your pocketbook.
