A few months ago I saw in a thread that somebody depleted his battery to 0% (whereas normally it will not go down lower than 10%). I think it was after a hilly ride. At that moment I assumed that the last 10% are exactly for those circumstances were you need to scale a decent slope for a decent distance. If the system would let you go down to 0% battery available, and then you would need to scale that same hill, then all you would have available is the ICE. And since it doesn't clutch to the shaft at lower speeds, you would only have about 60HP available. Can't imagine how to lug a 4000+ ride up a hill with only about 60HP, and no gearbox to shift down!
It should go into serial hybrid mode, so the low gear of the ev drive moves the wheels. Not sure how much power you can get this way though it should be more than 60 HP.
