"Drivetrain: Check Soon" -> Extended Dealer Troubleshooting?
  • Thread starter Thread starter KP_Aero
  • Replies Replies 13
KP_Aero
Wondering if anyone has had a similar experience as I'm currently having with my 2020 Mini SE.
Starting early summer I started getting intermittent "Drivetrain: Check Soon" errors. Typically they would reset on shutdown and disappear, reoccurring one drive every week or two. Car ran totally fine otherwise.
I took the car in to my local dealer in early September; they kept it for a day for troubleshooting, implemented the battery overheat recall software update, and sent me on my way.
Got a call back on October 1st, saying "Corporate needs your car to come back in ASAP" - no formal recall, no real explanation, just that they needed to do more work and troubleshooting on the HV battery.
As I write this it's October 28th, the local dealer knows basically nothing ("your car is up on the lift, the HV battery has been removed and disassembled, corporate is working on it"). The dealer states that my SE is one of two currently being worked over by "corporate" for extended diagnostic.
Luckily everything's been free of charge with a loaner provided so far - but the lack of information and lack of communication has been almost total. Just curious what might be going on, or why "corporate" needs to poke around in my HV battery for a month. (FWIW, my car isn't listed under the recent battery sealing recall...)
I was held hostage by a ChargePoint DCFC a few months back. No estop. 20 minutes on hold to get a human to remotely shut it off. My car already had a sticky HV error from another DCFC, so I dunno if this added one.
I was held hostage by a ChargePoint DCFC a few months back. No estop. [emoji638][emoji[emoji6[emoji640][emoji638]][emoji640][emoji6[emoji640][emoji638]]] minutes on hold to get a human to remotely shut it off. My car already had a sticky HV error from another DCFC, so I dunno if this added one.
You can stop the charging from the car infotainment. The car has to be in accessory mode, then find the menu to control charging current etc. “End Charging” is somewhere in that menu.
Your "Drivetrain: Check Soon" issue seems linked to an ongoing investigation into your HV battery, likely due to safety or performance concerns, even without a formal recall
I know this thread is old, but checking to see how this was resolved or if anyone else has had similar issues. Our 2022 SE is at the dealer now, with a "drivetrain: check soon" message too. It's been a few days, and dealer service dept is not saying much. Car was driving fine. And the alert in the car said it was fine to drive, just that it should get checked out soon. Again the service dept has been vague, but it seems they're checking all the batteries, one by one, and they told me after each check they have to email corporate and wait for an email response, so it's taking a long time.
car has 21K miles; we've had it for almost five years
It's the EV equivalent of a "check engine" light. I'd expect many different problems could activate that same cryptic message.
I've never seen that message and look forward to learning what caused it. If it pops up on my dash, I'll see what codes my OBDII reader can pull. (That almost sounds like I know what I'm talking about, right? I actually use the OBDII reader only to activate my AM radio using Bimmercode.)
Best of luck with your dealer's service department. I'm sure they're making phone calls we can't make.
Report from dealer : DETECTED FAULT 21F286- HIGH VOLTAGE BATTERY UNIT, CSC TEST OF THE SAFETY CIRCUIT FAILED, RESPONSE OF CSC MISSING, AND 22285D- HIGH VOLTAGE BATTERY UNIT, MULTIPLE FAULT, FAULT CATEGORY 3, CHECK CONTROL
The 12V battery passed an “energy diagnosis” but failed a load test, apparently. They recommend replacing the 12V ($763), and then they will recheck to see if this clears the faults.
Dang! I knew that replacing the 12V battery in a MINI wasn't cheap, but $763?!?
Does the MINI 12V battery have gold-plated terminals? I was planning to have mine replaced this fall. How hard could it be for me to remove the cover and replace it myself? If I use one of those cigarette-lighter temporary battery substitutes, would that prevent any required reprogramming?
It's a common or garden H5 AGM. You are supposed to pull the HV disconnect before replacing it.
I had a lot of those messages, they cleared up by themselves. Always after DCFC. Dealer was unexcited by them and said they weren't an issue and to ignore. Anyone heard of the boy who cried wolf?
