My solution was to put cheap big box window foam gasket seal in. This is not glued in yet, as I am testing it, but I have to admit that the car is noticeably quieter and there is far less wind noise now. As to appearance, well – they all pass the 3 foot rule easily and in fact are very difficult to see unless you know what you are looking for (photos attached). Took 5 minutes and $5. You be the judge. I might have preferred black seal for the charge door, however the part of the seal that is visible actually matches the pin striping the dealer applied. If you are wondering, the seal does not impact opening the charge door, although increases the close force just slightly. I do not expect it to be any source of concern and may keep the rain (or car wash spray) out of the cavity. Again, just presented as an FYI with YMMV.
Gasket foam was on hand, also didn't have the bag they came in but measurements were: large black was .5x.3 inches, and small grey was .3x.15 inches.
