I'm glad I bought my SE back in 2020, before MINI started installing batteries that failed earlier if you charged them to more than 80%. I thought the 110-mile range was just enough--88 miles wouldn't be enough.
I'd love to learn what level of MINI executives were involved in that change to the Owners Manual and how the decision was made. If MINI had changed the BMS to provide 137.5 miles of EPA range and then suggested owners should charge to 80% (110 miles range), it would all make sense to me. But I would have expected MINI to provide a BMS with an 80% charging option.
MINI certainly knew that a car that offers only 110 (or 114) miles of range would be charged fully every time. So I assumed the BMS was designed to prevent battery degradation caused by full-charging. MINI has my home address, but didn't send me an updated Owners Manual or an bulletin explaining the new 80% suggestion.
Does BMW tell customers of their BEVs to charge to 80% unless they need the full range?
It could be worse: Toyota decided owners of their bz4x BEV crossover can use DC fast-charging only 2 times in 24 hours!
It's unclear whether your 2020 is different here, but the general unstated reason against opting for low range EVs is how quickly you go through charge cycles, a cycle being generally understood as doing a full 0-100. With a larger battery, this takes a lot less time.
Your warranty is how you should probably be measuring the expected lifespan of your vehicle's battery. If we all go in excess of that? Good for us, but it speaks to BMW's confidence level towards its product.
Another issue is we're putting a lot of stock into earlier ownership experiences from the past decade, it's safe to say these owners were severe EV enthusiasts/apologists given the limitations of their cars. Will BMW turn into another Nissan as far as replacement packs go? Who knows yet! I'm just glad we're already clear of the way Merc handled the Smart EVs and their self-destructing batteries.
The fact of the matter is, we're driving a retrofitted me-too EV that just happens to be the most fun of the bunch at a time where EVs are just becoming mainstream. You're bound to have manual updates like that come along as well as a metric ton of misinformation.
