Defective (hazardous) portable EVSE
bwilson4web
Subscriber
With a home made NEMA 14-50 to NEMA 5-15 adapter, I was able to test the unit at 120 VAC and it is a disaster:
Tested with my Tesla Model 3, I could control the amps only to find the EVSE is unsafe to unsophisticated EV owners (aka., ex-wife.):
  • Initially tried to draw 31 A, the Tesla default
  • Stepped Tesla amps to generate the above chart
  • Typically 80% of the circuit breaker is the maxiumum safe load
    • 12 A - NEMA 5-15
    • 15 A - NEMA 5-20
    • Lower currents are OK and sometimes needed if other loads on the circuit
I've already submitted a 'return' request and will be shipping it back. But I am quite disappointed by this unsafe performance.
BTW, just bought a used:
"WORKERSBEE Level 2 EV Charger, 110V-240V 32Amp, NEMA 14-50 Plug" This one has a manual, current set switch. After I test it, I'll gift it to my ex-wife for her BMW i3-REx.
The unit is not defective. It has a 50A cord and plug on it. Defective would be if it tried drawing over 40A from a 14-50.
An adaptor made with a 14-50 socket and a 5-15 plug is not legal, safe nor sensible.
No EVSE knows what the wiring is the other side of its power plug. It should be plugged into a suitable circuit, or bad things can happen. Would you put a 5-15 on a stove?
The correct way to hook this up to 110 would be by removing the 14-50 and fitting a 5-50. Then you could plug it in to a suitable 40/50A circuit.
