Shawn Schinkel
Post away! Charging times on different size chargers, winter speeds, and anything else you can think of!
This makes more sense than the results the guy in this video got. Maybe his charging station wasn't working quite right in the chill. Thanks for posting!Last fast charger I used was at 4 degrees c. 50kw charger from 30% to 80%, ramped up to 48kw. around 72% it started ramping down to 37kw down to 26kw. I think it took around 52 minutes. Battery temperatures showed 15 degrees c. near completed charge, battery temps started at 10 degrees c.
Has anyone used the Greenlots app here in BC for DC charging? I hear it's the one to use but the reviews on Google Play are pretty horrendous. I was hoping to get an unbiased, real life user opinion - or is there a better app? Thanks in advance.
Thanks Dan!The DC charger here in Vernon is Greenlots, so I installed the app before trying out the charger a couple weeks ago. Worked fine, no issues. I didn't need the app for anything other than scanning the QR code to get it running though.
