Genevamech
Random peanut gallery comment: any chance the noise is coming from the scroll fan for the HVAC?
Even with the HVAC "off", IMO the HVAC fan is still pushing a small volume of air into the passenger compartment .
My first thought was a dodgy vent damper, which at motor operated to direct the air to windshield/forward/footwell. If there's a loose linkage or the motor is twitching for some reason then it could make a noise. The fan running is also entirely possible, but I don't think the fan is anywhere near where the noise is described.
One way to check is to turn the fan on at various speeds and see if that affects anything. Might be hard to tell if the issue is intermittent though. You can also get a cheap borescope and peek through the vents in the console to investigate, assuming you think the noise is coming from the ductwork.
