Lars
So much for reduced operating costs of EVs. Here is what my dealer quoted me for the first two services. I find these outrages for what the work involves. Service #1, a 30 mimute job w/o tire rotation, is mostly just 'take a look'. (I get free tire rotation for my Nokians from the tire shop and I change the cabin filter when needed.) Just for laughs; the oil change offered by the dealer, in writing, is C$59.95.
Service #2 ditto. Enriched by work related to breaks, checking more hoses and bolts.
With the exception of checking driveshafts and boots (CVs are costly to replace) the rest is really useless.
Don't forget to check the lights!!!
2021 KONA EV Maintenance Schedule
12,000km - Service #1 includes:C$99.95
- Tire rotation
- Check fluid level (coolant and washer)
- Inspect exterior lights
- Inspect tire pressure
- Inspect driveshafts and boots
- Inspect steering gear box, linkages and boots/ball joints
- Inspect climate control/cabin air filter (Replace if necessary)
- Tire rotation
- Check battery condition and terminals
- Check 12V battery condition
- Inspect cooling system hoses and connections
- Inspect disc brakes/pads
- Inspect suspension mounting bolts
- Inspect brake lines, hoses and connections
- Inspect air conditioning refrigerant for any leaks
- Inspect air conditioning compressor function
- Inspect brake/clutch (if equipped) fluid
- Inspect clutch (if equipped) and brake pedal free play
