Eric, in my case when the climate control is remotely turned on (using HL), with the charger in and not charging, the charger turns on. Therefore the battery is not losing any charge while the remote climate control is on and working.When the car is preconditioning while plugged in, is the batter losing any charge? Or is the 120V outlet able to "keep up" with the energy that is being used for the preconditioning?
From other posters' reports, I thought only a Level 2 EVSE could keep up with the power demands of preconditioning.Eric, in my case when the climate control is remotely turned on (using HL), with the charger in and not charging, the charger turns on. Therefore the battery is not losing any charge while the remote climate control is on and working.
I noted the charge on the HL and in the car before I turned the climate control on. After the 30 minutes of climate control being on and the car charging at the same time the amount of charge shown on the HL showed the same amount of charge as when I started. Thus my assumption that the battery on L1 was not being depleted by the climate control working. Now that I think of it, after the test , I did not verify that the amount of charge as shown in the car was the same as what was shown on the HL. I suppose I can test it again.From other posters' reports, I thought only a Level 2 EVSE could keep up with the power demands of preconditioning.
Car was plugged in with 240v but on the day when the climate control worked was very similar to the day when it did not worked. Things will be clear in Canadian Winter were all temperature in Garage and in Car will be low enough, Thanks all
Tested the remote climate control again (from the HL app) to see if the charging (L1) would deplete the battery. Battery EV charge prior to test was 29. After climate control was turned off (26 minutes) EV charge was 30. First screen shot is pre C.C, second screen shot is post C.C, third photo is from car.From other posters' reports, I thought only a Level 2 EVSE could keep up with the power demands of preconditioning.
Thank you!Proof is in the pudding:Tested the remote climate control again (from the HL app) to see if the charging (L1) would deplete the battery. Battery EV charge prior to test was 29. After climate control was turned off (26 minutes) EV charge was 30. First screen shot is pre C.C, second screen shot is post C.C, third photo is from car. View attachment 2753View attachment 2754View attachment 2755
make sure charging is done but still hooked upHow did you get your Honda Link to start the precondition while charging at 120? Every time I try it it says it can’t on level 1.
Claritydfw, I plug the car in and it starts to charge (because the charge is less than 100%). I then push "stop charging" on the app. I then turn on the climate control and about 20 seconds later the app says that climate control is on. The app shows that the car is now charging again [emoji4]. If you want to verify that the app is telling you the truth make sure you get in the car NOT using the drivers door.How did you get your Honda Link to start the precondition while charging at 120? Every time I try it it says it can’t on level 1.
I read this on reddit as a workaround for the SXM bug after pre-conditioning. It works every time I've tried it.
When you get into the car and close the door, the dash animation starts -- similar to when it shuts down. Wait for it to complete, then hit start. If you do this, the SXM radio will work, even if you've pre-conditioned. If you hit start before the animation completes, then SXM doesn't work.
I'd like to know this too. If the car is turned of with front and rear defrosters on, does the preconditioning put them on? Also, do the seat heaters come on during precondtioning?Is there any way to get the pre conditioning to turn on the front / rear window defrosts? I park outside and while the cabin is comfy, I can't see out of the windows (esp rear, front clears up quickly after I get in).. since I start my drive by reversing out of my drive way it is annoying that it doesn't turn on the rear window defrost while pre conditioning the car.
Mark, I ran a test this morning to see if I could get the driver's side seat heater to come on with the remote pre-conditioning (pc). The car was at 100% charge this morning. I turned the car on with the charge cable in the port of the car long enough to turn on the seat heater and then turned off the car. I then turned on the pc (see screen shot 1). At 15 minutes of the pc being on I got into the car using the rear drivers side door to see if the light was on to the seat heater. The light was not on and the seat was not warm. I tried to turn on the seat heater, from the back seats, and the seat heater would not turn on. So . . . . no luck on the seat heater coming on while pre-conditioning.I'd like to know this too. If the car is turned of with front and rear defrosters on, does the preconditioning put them on? Also, do the seat heaters come on during precondtioning?
