Long story short: My 2-month old 12-Volt battery died because we didn't drive our Clarity enough.
Long story long: The Clarity displayed a strange symptom and I tried this bunch of stuff before finally hooking up a battery charger to get going again:
Two months ago my dealer installed a new battery in our 2018 Clarity with 14,000 miles on the odo. We've driven our Clarity
PHEV a few times since then, but not in the last week. Today, when I tried to start the Clarity, it made the start-up sounds but the dash never lit up and the Power button started pulsing red and wouldn't respond to additional presses. Holding the fob against the Power button didn't make a difference.
The Clarity Owners Manual doesn't describe the pulsing Power button in the "Power System Won't Start" section. I turned to the section titled, "Emergency Power System Off," which reads:
- Press and hold the POWER button for about two seconds.
- Firmly press the POWER button three times.
That procedure had no effect. The Power button continued to pulse.
Pressing the charge-lid button caused a loud click, but the charge-port door wouldn't open. None of the fob buttons had an effect. When I got out of the car, the Clarity sounded "you're getting out of the car without turning it off" warning. I returned 10 minutes later and the Power button was still pulsing red about once a second.
I took the second fob into the car and pressed the pulsing Power button again. That caused the "you're getting out of the car without turning it off" warning to sound, but nothing else happened. The warning didn't sound again with subsequent presses of the Start/Stop button. The Clarity wouldn't react to any of the second fob's buttons.
I opened the charge lid by pulling the manual charge-lid release lever under the dash. The Power button stopped pulsing and went dark. Nothing happened when I plugged in my EVSE. Now I wish I had tried plugging in the EVSE while the Power button was still pulsing. Maybe there was a chance it might have started charging both the traction battery and, in turn, the 12-Volt battery.
A year ago the original battery went dead after not driving the Clarity for two months. Due to interference from garage shelves hanging over the hood, I had to
crawl along the floor on the right side of the floor to attach a battery charger. Fortunately, I didn't park the Clarity so close to the right side of the garage this time so I didn't have to crawl next to the car after opening the hood 6 inches and propping it up with a cardboard box.
I charged for two minutes, disconnected the battery charger, and the Clarity started--without the usual fireworks display of multiple warnings that usually accompanies a 12-Volt battery reset. I turned it off and tried starting it again. The two-minute charge was exhausted and I got the pulsing Power button again. I plugged in the EVSE, but no dice--it didn't begin charging.
After an hour of charging the Clarity powered up and the multi-system instrument panel fireworks display commenced. The TPMS system needed to reset, as did the vehicle stability system. The recalcitrant Clarity didn't want to back out of the garage, displaying the message "Gear Unavailable. Try Again After Awhile." Awhile later, I was able to back out and go for a short drive. As always, I hated the sound of our neglected Clarity's rusty rotors going swish-swish-swish even when I wasn't using the brakes and swishing louder when I was turning a corner.
I was happy to discover the radio-station settings didn't go away. I was unhappy to discover I couldn't lower the rear windows from the driver's armrest console. I parked, reached back, and found the rear windows would respond to their own switches. After that, the rear windows would respond to the switches on driver's armrest console.
Upon returning from my short drive, I plugged in the Clarity and it was happy to begin charging. The battery had about a 75% charge before this get-to-know-your-Clarity Saturday.
I'm still unclear what the pulsing Power button display is supposed to indicate. Is the car saying "I have just enough power left to avoid a 12-Volt reset if you charge my battery now" or is it just telling me "My 12-Volt power is all but gone--I have just enough left to signal 'Goodbye cruel world'"?
I can think of two options for preventing this problem from re-occuring: stop choosing our MINI Electric over the Clarity for every short excursion (ie.
every excursion these days) or install a battery-tender cable I can access without raising the hood.
