bobcubsfan
A thought: Would the EPA be interested to know that the programming in the Clarity that causes the ICE to come on unnecessarily is wasting gasoline?
Are you pressing past the detente on the go-pedal? Have you tried it yet? It automatically kicks ICE on, but perhaps doing that will also reset something and get your car back into a more mellow mode…
It's really not normal for the car to be going into HV mode so often. As a comparison, the last time I bought gas was six weeks ago. I drove 633 miles in that time and used 3.7 gallons of gas. So obviously, the ICE comes on, but I'm almost always aware of it. Either I run out of EV range or I purposely put it into HV mode. There's one extended uphill where a freeway starts that I had to learn to accelerate on so that I didn't always push the car into HV myself, but those situations are about the only times I end up being in ICE mode. What I'm saying is that it seems abnormal for the car to be in HV mode so often. Have you also tried doing some HV button pressing? Maybe that button or circuit is gummed up somehow.
I’m thinking that since it happened on a full charge with regen almost not being allowed and within 2 weeks/245 miles of previous ICE operation that it wasn’t a System Check. Maybe it was due to car not being able to brake by regen resistance and called for ICE for braking purposes as some have speculated. Just a WAG on my part.
Totally agree. And for me, my results are indeed reproducible. If I charge up full and unplug right before I leave, then brake (or try to apply regen braking) as I go down a slight hill a block away from my house, then the ICE will come on. If I unplug at least 30 minutes before I depart (giving a bit of time for self-discharge) or if I only charge to 95%, then doing the same drive behavior does not cause the ICE to turn on. Since it only comes on when the battery is maxed out in charge, it seems to me that what I'm experiencing with ICE turning on is due to maxing out the regen capacity of the battery.Basic science. Experiments and results need to be repeatable. For example, mixing vinegar and baking soda will result in foam from carbon dioxide. It happens all the time. Don't respond with the baking soda and/or vinegar may be bad. You get the point. If the ICE comes on when the battery is full and one brakes, then it should happen every time, not once in a while. There has to be something else going on that is causing intermittent behavior.
Absolutely agree. Mine does exactly the same thing in this circumstance and I notice that I get practically no regen braking until I’ve traveled a little further.Happened again this morning. Temp 13C charge was 100 percent. First stop sign fine second one which required heavier braking it turned on.
I pulled over. Turned off car and waited a minute turned it back on and back to pure ev the rest of the way.
This has nothing to do with maintenance as half of my kms have been on gas this past week so that argument makes no sense. This engine gets the same or more use as a typical pure ice car. This has to be tied to 100 percent battery and breaking with no regen space.
Bob, was this leaving home with a full charge and how heavy was the braking?New Incident. Leaving our house we drive the same pattern. Slight downhill for half a block to stop sign. Right turn again slight downhill to stop sign. Turn left to light. Stop if necessary. Right turn to stop sign. The total distance from home to the third stop sign is .3 miles. Today, after several days of "good behavior," the computer decided to turn on the ICE just BEFORE the third stop sign. The ICE sounded as if it were revving high. I "rebooted" by shutting down and restarting. Once, that I noticed, the EV light went off then on again in about 1 second.
