David Towle
Insightman are there any drawings that show how this works? I think what you are saying is above 45 mph there is a direct single speed connection, and below that the engine/generator can bypass the battery and send power directly to the electric motor. What this means then is there is actually LESS than 103 hp available below 45 mph as generator/motor arrangements usually have more losses than mechanical connections, so probably 90 hp or so. And above 45 mph its unlikely the engine is operating at its power peak, so there we are also somewhere under the 103 hp.The single-speed transmission is in effect only when you're cruising above about 45 mph in HV Mode, when the Clarity's clutch can (at the computer's discretion in the interest of efficiency) connect the output of the engine to the gears driving the wheels (Engine Drive mode). Most of the time, the i-MMD system is performing as an eCVT, where the battery along with the engine driving the starter motor/generator provide exactly the amount of power for your driving needs. Because the engine speed is not directly proportional to the road speed when not in Engine Drive mode, the collection of mechanisms Honda calls an eCVT performs much like a conventional CVT.
So with a 4100 pound car it sounds like the best thing to do if you run out of battery is pull over in long push HV mode and give it a half hour to charge the battery.
