Clarity EV DCFC rates
JyChevyVolt
EVGO has two types of 50kW fast chargers Terra 53 (125A) and BTC (100A).
On BTC DCFC
33% SOC 314V 101A 31.7kW
70% SOC 328V 99A 32.5kW
79% SOC 335V 84A 28.1kW
I will update with more data.
On charge point express and Terra 53
0*-70% SOC 36~40kW
71-95% SOC 28~27kW
95%+ SOC, 346V, 2 amp reduction every second.
It's best to fast charge up to 95%. Clarity EV has about 22kWh usable with about 1-2 kWh reserved.
*Yes, drove in reduce power mode for 4 miles, uphill!!!!!!!!
Here is a session on ChargePoint Tritium, 125A. Starting @58% SOC. Best I have done is 44kW on EA station. Miles of range is weird.
Weird is right! That would equate to less than 50 miles on a 100% charge, far short of the nominal EPA range of 89 miles.
Could be some bad data somewhere. 48 miles is the official amount of miles a fully charged Clarity PHEV gets. Could someone have grabbed the wrong value when the app was programmed?
Coming from Bolt, I thought DCFC (DC fast charging) is only CCS (e.g. Bolt, connector type, standard) or CHAdeMO (e.g. LEAF, connector type, standard), typo in the title? I do not think any Clarity has a DCFC connector or capability.
Clarity DCFC might be nice, but one of the down sides of Bolt is the relatively high cost of DCFC EV charge stations by time, not by the actual amount of electricity provided.
Do you mean that some of those stations (e.g. EVgo) also offer regular (AC power) L2 plugs now too?
I should read more carefully! That is cool that the Japanese PHEV has it, too bad we did not get it here on the PHEV (although DCFC can be more expensive than gas!)
Charged up at a BTC 50kw station. Got there at 7% charge and charged for 35min. Started at around 37.5kw and peaked at 40kw. After my 35min it was showing 60% charge.
