vicw
Agreed... Well, it was worth a try, Here is the static data I have collected so far from a few others:
@sabase is completely dead, and @vicw is questionable.
If you get the opportunity, it would be worth checking the static pressure again at a higher ambient temperature. If the Freon is low, it will fall off of the curve at some point as the temperature increases. Perhaps that is what is happening with @vicw although his seems to be working.
Operational data may be useful, but all I have so far is a single data point... I had 140 psi with an outside temperature of 88 F and an inside set point of 75 F.
That's a good start on the data reported so far. I'm eagerly looking forward to reporting and seeing others showing more input showing the static and operational pressures at higher temps, but we are currently in a cool cycle this week, so I will have to be a bit patient on that.
There is one point that keeps confusing me, though. We are charting 'Outside Temperature' as a variable, which is self-explanatory, but the data being reported in Car Scanner shows it as 'Temp Out', which could be considered to mean the Temperature of the air coming out of the A/C system. Assuming it really does show the Outside Air Temp, renaming the variable in the Dashboard, perhaps as 'Outside Temp' would be helpful to avoid confusion.
The 'Inside Temperature' variable is shown by the Scanner app as 'Temp In' is less confusing, since it does reflect the air temp going into the A/C system from the cabin using either naming, but if the 'Temp Out' were to be renamed in the Dashboard as 'Outside Temp', renaming 'Temp In' to 'Inside Temp' would pair well with it, and avoid confusion.
