MarkClarity
My condenser failed, but dealership says it is on backorder with no ETA. Anyone else waiting on a condenser? Wondering if this is a couple of weeks, or several months!
A cursory inspection of what I can see of the condenser w/car on ramps does not reveal any oily spots. I put what I'd guess to be 2/3 of a 12 oz can of R-1234yf in it last Friday (21 June, 2024) and as of yesterday afternoon it was still performing admirably.
In the manual, it lists the refrigerant charge as 13.9 – 15.7 oz. If you clearly notice that the cooling is degraded (but not yet 'dead'), my feeling is that most of the refrigerant is gone. So, I think the 2/3 of a can (~8 oz) that you added is conservative. In reality the whole 12 oz can may have safely gotten you closer to a full charge, but you were being cautious. With gauges (and knowledge of the charging procedure) you could more accurately top it off.Of course, without knowing how much charge remained, it is not possible, apart from blind luck, to restore the system to the properly specified charge level
I STRONGLY advise not even touching the A/C system. R1234YF is *really nasty* stuff when it gets contaminated, and it's really easy to dig yourself a deep hole in your wallet by "fixing" the AC system yourself.@MrFixit provides sound advice. That was part of my calculus in purchasing the can of R-1234YF locally on Friday even though I had already ordered a supply online that was inbound. Also inbound at the time but not yet (at the time) having arrived were adapters to allow fitment of my manifold & gage set as well as a can tap with the appropriate LH threads. Having "some" evidence that it was a slow leak, I did not a) want to continue to be uncomfortable after a day-long hot soak in the afternoon commute and b) allow the refrigerant to leak to the point that it's static pressure was below atmospheric, leading to ingestion of contaminants.
Of course, without knowing how much charge remained, it is not possible, apart from blind luck, to restore the system to the properly specified charge level. And if one were to evacuate the system and pull a vacuum, with an unknown and unmended leak...well same as inducting foreign matter previously discussed. Haven't yet had time to put the gauges on it and check pressures but will do so prior to the upcoming road trip of approximately 2.5K miles. Doubtful I will have opportunity to turn it over to the dealer for 1.5 days prior to that and also dubious that it would be returned working as well as it is now if I did. If, in fact it is a condenser failure (or evap failure as many here have experienced) I would not expect a timely repair - in the case of the former I doubt a dealer in NTX maintains inventory of Clarity condensers, especially if generally on back-order, and in the case of the latter, I would probably waive the dealer fix and associated charge and continue feeding it over-priced refrigerant until retirement when I could tear the dash apart for evap replacement at my leisure. In any case, I would expect as part of diagnosis, the dealer would hook up their recovery machine and perform an evacuate and recharge, likely leading to a contaminated system...or worse, "You have a leak, we don't have parts so can't fix it yet, and we're not allowed to charge a system with a known leak.
Even at $80/12 oz, and the thus far demonstrated leak rate, this would still be cost-effective vs. saddling up one of the other vehicles in my stable for the 100+ mile daily commute.
Please elaborate. There are hazards with any refrigerant.R1234YF is *really nasty* stuff when it gets contaminated
When r1234yf reacts with air it makes acid that trashes refrigerant systemsPlease elaborate. There are hazards with any refrigerant.
I concur with your theory, another thing too is that typically the amount of time where you have to pull a vacuum in a r1234yf system is longer than that of other refrigerant systems, and at a dealership you really don't want to take up much time, so less time than it should would be taken pulling a vacuum.TC1782's comment about the POE oil used in AC systems with r1234yf refrigerant can be expanded. The POE oil reacts with the moisture in the air to form an acid which is highly corrosive. The filter-dryer in the AC system will not remove the acid after it is created by the POE oil reacting with the moisture.
I have a speculation about the failure of some Clarity AC parts after the condenser is replaced. The system should be left open a very minimal amount of time during the condenser replacement. However, some service technicians may leave the system open a very long time. This allows moisture in the air to react with the refrigerant creating the acid. This acid can damage the new condenser as well as the evaporator. This might be able to be checked by Honda looking at the Clarity repair records to see if most of the evaporator failures are after condenser replacements.
Again, this is only a speculation.
LeoP
