electriceddy
Moderator
Note: in an emergency, one can use the e-brake as well .
After 2-3 weeks of wait, we have our car back with a new braking module. The answer to the question I had posed regarding whether there is a fail safe on the regenerative braking is: no. Unfortunately, if the regenerative brakes fail, the hydraulic brakes are not triggered.
This is probably what happened. The regenerative brakes failed so no braking was produced. The fact that we had a sporadic 'check brakes' sign is re-assuring: a brake fail should not happen if you go back to the dealer to have it checked.
But the fact that Hyundai had originally sent us back home with a defaulting vehicle because they could not locate the issue with the brakes is appalling to me. If other out there have this sign, don't let Hyundai send you back home because they can't find what's wrong. It could be very dangerous in my opinion.
Scary stuff, good thing the 3rd pedal depression kicked in. I had the same 01D102 performed on January 7th, 2021 and will definitely keep alert if any similar warning lights produced while driving or pedal "kick backs" when coming to a stop. When you finally receive your car back (hopefully repaired), could you kindly post the part# of the IEB unit from the shop invoice...it might help speed up repairs for those who might encounter a similar issue in the futureI had a recall #01D102 (R0178) performed on my 2020 Kona Preferred on in Mar. 2021. The problem: "Vehicle equipped with Integrated Electronic Brake (IEB) system that might significantly reduce braking performance upon detection of an abnormal sensor signal. Reduced braking power could extend the vehicle stopping distance." The procedure was an IEB unit software update.
In June of this year the "Check regenerative brake" warning light came on and the parking brake light came on at the same time at random intervals when driving. The regenerative brakes were operating ok and the parking brake was in fact not on. I took the vehicle in to Hyundai Victoria but the mech. could find no reason for this so I was sent away and told to monitor.
This kept happening randomly and in July, twice when coming to a stop using the hyd. brakes and with regen. braking in position #2, there was a kickback on the brake pedal and the "Check regenerative brake" light came on at the same time. The veh. did stop ok. I took the veh. in to Hyundai again and they still couldn't find a reason for this happening. After leaving the dealership the warning came on again so I turned around and went back so the mech. could plug his reader in while the warning was displayed. I was told they should be able to find the cause now and they would call and let me know what they found but no one called.
About a week later when the brake pedal was depressed to come to a stop the pedal was hard and unresponsive and all the warning lights and buzzers on the dash came on at the same time. The brake pedal was pressed again and harder but still would not stop the veh. The third time the pedal was depressed the brakes all of a sudden worked and the veh. came to a sudden stop.
I took the veh. back in to Hyundai next day and it's been there over a month and a half. They determined that they would have to replace the IEB unit but couldn't find the schematic to get a part# to order by. They eventually found the part # and the unit should be here by Sept. 12 although I'm not holding my breath.
Yes, I'll see what I can do.Scary stuff, good thing the 3rd pedal depression kicked in. I had the same 01D102 performed on January 7th, 2021 and will definitely keep alert if any similar warning lights produced while driving or pedal "kick backs" when coming to a stop. When you finally receive your car back (hopefully repaired), could you kindly post the part# of the IEB unit from the shop invoice...it might help speed up repairs for those who might encounter a similar issue in the future![]()
It's an expensive unit and that's why I'd suggest that periodic brake fluid changes are more important than in ICE cars. The blended braking is also a vehicle feature that Tesla doesn't have.... They determined that they would have to replace the IEB unit but couldn't find the schematic to get a part# to order by. They eventually found the part # and the unit should be here by Sept. 12 although I'm not holding my breath.
Update: The dealer said that it wasn't just the "Stop Vehicle & Check regen brakes" light that came on, he said that it was every other lights. Now they managed to turn off all the lights (reset) and went through but could not find anything wrong other than that a part needed to be replaced and that it will take about a month for the part to arrive. In the meantime, they have driven the car and found no problem and if I wished, I can leave the car with them until the part arrive or drive the car home while they arrange to have a loaner vehicle for me since it is a safety issue. It will take a couple of days to arrange for the loaner so I drove my Kona home (without any issues) but was driving very, very cautiously like making sure that I stay below the speed limit and that I take my foot off the gas pedal and gently press down on the brake pedal after ensuring that regen braking was working. I did not understand which part requiring replacing but guess I will find out when it arrive.So today while driving, my brakes failed. Luckily I was already reducing speed when the brakes failed but still unable to stop in time and hit the vehicle in front of me which was stopped for a red traffic light. No major damages (minor scratches/indentation) but really lucky that there was a vehicle otherwise I would have gone into the intersection and either get T-boned or T-bone someone. I am now waiting for a tow truck to come and tow the car to the dealership to look at as I am not willing to drive the vehicle. Alert given was "Stop Vehicle and Check Regen Brakes" with all warning lights lit up.
Question: Did you try to apply the EPB when hydraulic failure occurred?Update: The dealer said that it wasn't just the "Stop Vehicle & Check regen brakes" light that came on, he said that it was every other lights. Now they managed to turn off all the lights (reset) and went through but could not find anything wrong other than that a part needed to be replaced and that it will take about a month for the part to arrive. In the meantime, they have driven the car and found no problem and if I wished, I can leave the car with them until the part arrive or drive the car home while they arrange to have a loaner vehicle for me since it is a safety issue. It will take a couple of days to arrange for the loaner so I drove my Kona home (without any issues) but was driving very, very cautiously like making sure that I stay below the speed limit and that I take my foot off the gas pedal and gently press down on the brake pedal after ensuring that regen braking was working. I did not understand which part requiring replacing but guess I will find out when it arrive.
Same question : Did you try the EPBThe brake pedal was pressed again and harder but still would not stop the veh.
You are right, I've had no time to engage the EPB with the regen brakes not working, first instinct was then to jam on the brake pedal and when that didn't work, pump the pedal and by that time, the car has hit the stopped vehicle in front. Like I said, I was lucky that I was already slowing down & coasting before the failure (foot off the gas pedal). Will need to keep the EPB in mind in the future.Question: Did you try to apply the EPB when hydraulic failure occurred?
I suspect the answers will be "no"
I tried 5 times this morning, from 30 km/hr application of the electronic parking brake stopped the vehicle with no problem, foot on or foot off brake pedal, also tried intermittent pulling of the center column switch and releasing before complete stop, it worked flawlessly.
More on EPB activating the rear caliper motors here
This will be my go to, should above circumstances occur. (providing the answers to my questions come back as a negative)![]()
Hyundai actually positioned the lever in a convenient location, with my arm resting on the center console it is easily applied without thought, not mixed up with the other buttons. A good go to if failure within the hydraulic unit or main actuator.having a finger on the ePB when slowing down.
