neil arundel
Most threads I have read seem to be USA. I am in Ireland and have had a pretty constant problem with getting my Kona to charge overnight to avail of cheap-rate electricity. I set it up properly (sorry, I'm not very technical) and the display tells me "Waiting to charge at scheduled time" but charge, it does not. It does if I go sit in the car after the set time and turn on the power. It then starts charging!!! Defeats the object of setting a time, and very annoying. Is there something wrong with the electronics in the car or with the home charging unit? Strangely enough if I start it charging shortly enough before the time it's set to stop then it does stop correctly. The dealer says there's nothing wrong with the car's electronics and the charging unit supplier has not been able to get to check the installation because of Lock-down! Well at least I'm not going anywhere!! Anyone else with the same problem?
