Charging with Portable Generator?
  • Thread starter Thread starter mikeg0305
  • Replies Replies 23
  • Views Views 3K
Take a portable generator. Remove ALL receptacles. HARDWIRE a cheap EVSE to it. Tie neutral to ground while you are doing that. This means it can only be used for charging EVs. Anything with receptacles, plugs and the ground and neutral tied somewhere will have a way to zap people if something unsafe is plugged in.
What if the neutral and ground were tied together in the plug for an EVSE that's used only with the generator? Would that still pose the possibility of getting zapped?
Are these neutral-ground bonding plugs for generators legal?
You may think I'm being paranoid, but I see dangerous stuff on a weekly basis at work. Far too much ungrounded equipment. Oh look the metal case is 277V, again... Mostly it's thanks to people 'fixing' things. One kludge may be ok, but add something else that is faulty or kludged and then you often have something dangerous. What I do in my own basement, stays in my own basement...
