Comparing the kWh required to charge, and the kWh consumed from the battery, I calculate a charging efficiency in the 60% range.
This seems terrible. This also indicates that the efficiency numbers (eMPG, or whatever) cited for EVs are disingenuous.
I verified the App reported numbers using a watt meter. As an aside, the Power Factor reported by the watt meter is 0.99, so that isn't the source of the loss.
This is all using the Mini supplied charging cable, in a garage at 40-50F, without preheating.
