ChargePoint Home Flex hardwired vs plug-in for a Portland garage?
michaelthomas
I drive a 2022 Chevy Bolt EUV and charge in an attached garage in Portland. The 240V outlet situation is making the decision harder than I expected. I've been comparing the ChargePoint Home Flex hardwired and plug-in versions, mostly because hardwiring seems to allow a higher amperage setting, while the plug-in setup would let me take the unit with me if we move. Our panel has room for a 50A breaker, but I'm not sure whether the extra headroom is worth losing the flexibility of a NEMA 14-50 plug. I also wonder how often people actually relocate these units versus just leaving them behind. The other concern is whether hardwiring complicates future service or replacement if something fails. For those who have installed the Home Flex in a garage, did you hardwire it or use the plug, and would you make the same choice again given your panel capacity and how long you plan to stay put? Any input from people who have lived with either setup would help.
Update after poking around more - the ChargePoint Home Flex Hardwired J1772 Level 2 EV Charger Review keeps surfacing in comparisons. Leaning hardwired since we plan to stay put, though I'm still unsure whether service or replacement later would be a headache.
How often will you need to unplug your EVSE? A plug presents a potential point of failure (see this post by @Rexsio) that a hardwired installation eliminates. Disconnecting a hardwired EVSE isn't difficult if you can determine which breaker to turn off and you can borrow a screwdriver. Another benefit of a hardwired EVSE is it's more difficult for thieves to disconnect.
My argument for going with the 14-50 plug is that when the wall EVSE fails i can still use a portable L2 EVSE that i have in my car ...rather than waiting for a reinstall by an electrician. A high quality plug installed by somebody competent ..i.e torqued the screws properly etc...has same risks as a hardwired.
the only difference is 9.6kW vs 11.6 kW
Good point. My 10-year old, used, 48-Amp, hard-wired, ClipperCreek EVSE has never failed. If it did, I'd be charging my MINI on 120 Volts until I wired up a replacement. It has a very large relay that makes the most satisfying KLUNK! after I plug in. I'll miss that audible confirmation someday when I upgrade to a thirstier EV.
I have never understood the argument that running something for 10 hours will discover faults that is not seen after 1 hour.
Usually I believe if something is rated 50A it means it can take 40A continuously with spikes of up to 50A. An electric wire won't keep building up heat..i.e the temperature it reaches after 30 mins should be the same after 10 hours of use.
For example if a dryer takes 24A for from an outlet for 1 hour I can't see why running a EVSE at 24 A from the same outlet will make the house catch fire on the 9th hour.
One can argue that the continuous slightly higher temperature than ambient will damage the insulation of electric wirings with hours of use...hence the reason to buy good quality wiring that should run for decades.
