Can't delete personal data like phone
quietlyspinach
So I'm stuck - I'm trying to remove an iPhone that was paired to my MINI and the menu option to delete the phone isn't working.
So Googling around, I see that many people had to delete everything, and the steps according to the manual are:
1. Go to My MINI
2. System settings
3. Data privacy
4. Delete personal data
5. Delete personal data (again)
6. select "OK".
7. Exit and lock vehicle.
Then wait for 15 minutes.
I've done this several times now and nothing seems to happen. In fact, when I do step 6, "select OK", it's like it doesn't even register that I've selected OK at all. The menu is highlighted, it dims/brightens when I depress the selection wheel, but nothing indicates that it is going to start any sort of process at all.
Anyone else ran into this problem? Is this something that can only be accomplished at the dealer?
At this point, I'm thinking I just want to power-cycle the whole computer but I don't know how that's possible at all.
You should be able to remove specific mobile devices like this in the Central Information Display:
1. Go to "My MINI"
2. Select "System settings"
3. Select "Mobile devices"
4. Select device.
5. "Delete device"
Yep. Tired that. It removed one of the 2 old users no problem at all, but when I’m trying to delete the one that’s left, nothing is happening. So weird.
Hrm. That definitely doesn't seem right. Maybe take it to your local MINI dealership to see if they can wipe it clean for you? They must have the right tools to do it, since they are probably required to reset any used car they sell.
I wonder if the secret menu has a way to wipe the infotainment system (you need to select unlock from the menu and I think enter sum of last five digits of VIN to get extra options, which if I remember correctly might be in German).
Hey man, sorry this is happening to you.
So I complained to my MINI Dealer about this and it took them *3* tries to remove it. The only way they could do it was to completely re-flash the operating system from the factory, so *everything* got reset. Hopefully there is a better method of doing this today.
Yeah that’s pretty brutal. Will probably just live with the old owners phone name existing there…will be like a wee homage to its lineage lol.
1. Go to "My MINI"
4. Select device.
5. "Delete device"
Has anyone tried disconnecting the 12v. Battery? It's the equivalent of unplugging a computer. Works at home!
How about renaming your device to match the old owner's name, and see what happens? Maybe you can "capture" the entry and then delete it. I'm not sure what identifiers the car actually uses internally, but might be worth trying.
