Found them on the Nokian website. Might have to special order…none found on basic search.Hakka 9 and 10 come studded in 195 55 16. not much choice of anything in 17” so downgrade to 16s
Your SE should have come with the tire mobility kit, which includes an air compressor and a bottle of goo to inject into a flat tire, basically like Fix-A-Flat. I have runflat winter tires on my ICE Clubman, but for the SE I stuck with standard winter tires (Hakkapeliitta R3s) for lower rolling resistance and less noise. And I did indeed get a nail in one of them last winter and drove around half the winter on a slow leak because I couldn't find a replacement. This winter I'm all set with a spare winter tire just in case, since they're basically only available at the start of the season.Another Question - none of the Hakka’s are run flats. Do you just throw a can of fix a flat in the car and go for it?
Gotcha, I vaguely recall this mobility kit. Im sure its still there.Your SE should have come with the tire mobility kit, which includes an air compressor and a bottle of goo to inject into a flat tire, basically like Fix-A-Flat. I have runflat winter tires on my ICE Clubman, but for the SE I stuck with standard winter tires (Hakkapeliitta R3s) for lower rolling resistance and less noise. And I did indeed get a nail in one of them last winter and drove around half the winter on a slow leak because I couldn't find a replacement. This winter I'm all set with a spare winter tire just in case, since they're basically only available at the start of the season.
I looked for 4 hole rims a few weeks ago, and saw a few sets of 5 hole Mini rims on the FB marketplace relatively local.Found them on the Nokian website. Might have to special order…none found on basic search.
I did find some used rims with Toyo snows for 750, but they weren’t studded and I think we really want the studs…we are at 8100 in Confer Colorado.
