prestoOne, I’ll try to answer these in order:
-FWIW, my Chargepoint came with the cord. They offer 2 different lengths. Don’t know anything about Canadian rebates as I’m in USA.
-Mine is 32 amp, any higher will be of no benefit to the Clarity. (32 amp requires minimum of NMB 8-2 wire and a 40 amp breaker but as always check national and local codes. Note that it does not require a neutral wire.)
-When not connected to the internet, the base will light up white for ready to charge, pulsing blue for charging, and red for fault. Smart phone is used for scheduling (or just use Honda Link) or to use CP app to track kWs. When connected to internet you get green for ready to charge, pulsing green for schedule set, blue for plugged in, pulsing blue for charging, and red for fault.
-As to possible theft: The cord is connected by spring toggle levers. So if someone were to snap off the decorative cover and unscrew the inner cover, they could take the cord, but they would have to work at it. Not a snatch and grab unless they cut the cord. Also hardwired makes it a little more work to steal the base as opposed to just unplugging. Tamper resistant bolts/screws could give you more peace of mind.
-The size is very unobtrusive and is especially shallow. Doesn’t stick out from the wall hardly at all. Definitely not an eyesore to mount outside. Cord storage is built in and loops around the curved top for a neat appearance.
-ChargePoint states the unit is suitable for outdoor installation if you buy the hardwired version. This is probably due to the plug-in version only having a 12” cord which makes it impossible to use a NEMA waterproof box/cover for the receptacle as code (and common sense) requires in my locale.
-Very easy to use; just unplug from base and plug into car. Has the same force needed as several other public chargers I have used. I have a surgically repaired arm/wrist and I don’t have any problems. Your wife will find it easy.
Hope those answers help.
I like mine a lot, especially the app that lets me track kW many different ways. You can use it without a smartphone or internet connection just fine but lose its best feature which is the tracking app.
