I'm looking into a new EV car. I would like one that has a battery heater, but I cannot find a source with the details for most models.
Anyone has a source, or at least per car confirmation?
I can try to make a Google sheet if we have enough information
Ooh that's a great idea. I guess you set it from the car?Another thing that helps with the kona, and likely with some other cars too, is to set your charging to top up the battery as close as possible to your departing time as recharging does heat up your battery a little. And you can also preheat the inside of the car so it is already warm before you leave the house.
How does the battery warmer work. What happens when the car has been sitting out in the cold when I’m at work? Do I need to warm the battery before I drive of? Does the vehicle maintain a battery temp when it is sitting turned off?The Kia Niro SX touring (56k CAD) has an heat pump and a battery heater, but not the EX (47k CAD).
Technology tab: https://www.kia.ca/vehicles/niroev/features
For Kona EV the battery heater (when winter mode is on) warms the coolant before it enters the pack.How does the battery warmer work. What happens when the car has been sitting out in the cold when I’m at work? Do I need to warm the battery before I drive of? Does the vehicle maintain a battery temp when it is sitting turned off?
