This response is spot on. I've had my 2018 since June and my EV range has dropped from a high of 66 to a low of 32 this week.Sounds pretty normal.
EV range drops in cold temperatures because you use the heater. (It is an electric heater to warm the passenger compartment.)
The chief reasons the gas engine starts with a full battery are excessive acceleration, and excessive deceleration. If you press on the accelerator too hard, the gas engine kicks in to provide extra power. If you have a panic brake, the gas engine is used for engine braking, then runs for warm-up and lubrication.
Have you noticed when the gas engine is running?
That never happens to me. I've stomped hard on the brake pedal in an attempt to remove rust from my Clarity's brake discs after it's been sitting for a while--the ICE never starts. However, it is commonly agreed on this forum that using the brakes--not necessarily in a panic stop--when the battery is fully charged can cause the Clarity PHEV to start its ICE. It's the most mysterious Clarity phenomenon to me.If you have a panic brake, the gas engine is used for engine braking
But the regen paddles start the ICE only when you've just fully charged the battery, correct?I have had that happen with the regen paddles. I haven’t tried it with foot brake.
Yes. You have to be fully charged and regen almost immediately.But the regen paddles start the ICE only when you've just fully charged the battery, correct?
Ditto and +1 on range loss to cold weather. We just got over having a high of 22 F and my EV range went from low 60s to mid 40s with seat heat and a little heater use. Used 1.03 kWhs to precondition on EVSE power.
Also today had the ICE come on less than a 1/2 mile from being fully charged with just 4 chevron paddle selection. Power Gauge As usual indicated just a small amount of regen was allowed. Ambient was 50 F and I had a strange charging graph for this drive when I charged after car was outside all night and morning at a friends instead of garaged. I charged immediately after driving home instead is my usual scheduled charge at 5 am. And I drove sedately at max speed of 55 mph.
Has anybody seen their charging look like this? It’s a first for me. Do you think it was due to a colder battery not accepting as fast a charge or a hot battery from just being driven? I didn’t hear any cooling fans running however.
Here is a representative charging graph when scheduled charging occurs after car has sat in unheated garage for 8 hours or so that shows the normal immediate ramp up to 7.12 kW charging rate that stays constant until the tapered ending.
Reverse engineering and figuring out this technological wonder is a daunting and formidable (but worthwhile and entertaining) task.
Can the Clarity Brain Trust explain this?
I’m guessing that the internal temperature of the battery pack is more important than ambient temperatures. So a cold soaked pack will charge not only slower but differently?
My guess:Recently drove 2018 Clarity (purchased Feb, 2018, under 13K miles) solo from South Ogden, Utah to Eagle, Idaho and back to South Ogden over a weekend. Round trip of 636 miles. Battery fully charged and HV mode used entire trip. Weather was nice and winds were relatively calm coming and going. No heat required. Most of trip was at 80 MPH. ICE ran approximately 75% - 80% of the time, mostly in angry bee mode. Averaged 34.64 MPG (manual calculation). Similar trips under similar conditions in the past, the Clarity averaged over 40 MPG with ICE running approximately 40% - 50% of the time and less angry bee mode. Will repeat this trip again next month. Anxious to see how Clarity performs then.
The random engine starts do appear most frequent with full-battery regen. I have had that probably 4 times over the summer, but now I monitor my regen every time I leave my house. In winter, I blast the heater to use up the extra regen.That never happens to me. I've stomped hard on the brake pedal in an attempt to remove rust from my Clarity's brake discs after it's been sitting for a while--the ICE never starts.
Sounds like you live in Utah as do I. You are finding the same results as I have driving your Clarity at the higher altitudes we have in Utah at 80 MPH. I had the same experience driving from Salt Lake City to Las Vegas at 80+ MPH. My engine also ran about 75 to 80% of the time, mostly in angry bee mode. I also only got about 35 MPG. I don't see those problems driving 65 to 70 MPH on the freeways and I average 40 to 42 MPG at those speeds. The little 1500cc engine really does not have enough power to propel the car at 80 MPH without running at high RPMs at altitudes above 5000 feet.Recently drove 2018 Clarity (purchased Feb, 2018, under 13K miles) solo from South Ogden, Utah to Eagle, Idaho and back to South Ogden over a weekend. Round trip of 636 miles. Battery fully charged and HV mode used entire trip. Weather was nice and winds were relatively calm coming and going. No heat required. Most of trip was at 80 MPH. ICE ran approximately 75% - 80% of the time, mostly in angry bee mode. Averaged 34.64 MPG (manual calculation). Similar trips under similar conditions in the past, the Clarity averaged over 40 MPG with ICE running approximately 40% - 50% of the time and less angry bee mode. Will repeat this trip again next month. Anxious to see how Clarity performs then.
Also, "no heat required", is an absolute statement. Looks like temperatures in Utah were in high 50's. If fresh air is selected, there will be some heat requirement. At those temperatures, it can be helpful to select recirculated air.
Just addressing this point -- Spinning the temp dial to "Lo" should give outside fresh air without heat or AC coming on, as long as you go to the Climate menu and turn off the AC. I do this every day. I'll save my rant on how inconvenient the climate controls are for those of us that prefer manually adjusting the air for another time!
