Brake system error message
  • Thread starter Thread starter PeterT
  • Replies Replies 9
PeterT
I have a 2020 SE with 13k miles that was just serviced 3 weeks ago. The service center did the battery cover recall, flushed the brake system and rotated the tires. Yesterday on a random basis I get the message: “Brake System Contin. driving possible”. Has anyone else seen this error message. The message goes away when the car is restarted but will pop up randomly but not every time we drive the car. Braking seems normal but I mostly use regen braking.
I have a same messages on brake system and dealer reset and for a week was ok but than I have a X-mas lights on dashboard second visit to dealer they replaced brake sensor on a right rear with broken tinny wire and is ok now $185 later is a pic.
and part number if you handy you replace yourself saving at list$120 I argue with dealer warranty didn’t cover 2022 SE 10000 miles
I have a same messages on brake system and dealer reset and for a week was ok but than I have a X-mas lights on dashboard second visit to dealer they replaced brake sensor on a right rear with broken tinny wire and is ok now $185 later is a pic. View attachment 22453 and part number if you handy you replace yourself saving at list$120 I argue with dealer warranty didn’t cover 2022 SE 10000 miles
Thanks for the info.
Sorry late answering this but you can reset the light with the button on the top left of the gauge cluster.
Turn the car on without pressing the brake pedal
Wait for the light to go out that has the alert
Hold the button down for about 10 seconds, you'll get into the service reset menu. Quick press cycles through the options, long hold is the "ok."
My car also had a flaky wear sensor (right rear) actually having it replaced under warranty as I type this.
Thank you so much for this picture! I had a hard time finding the correct part number. I just ordered this for mine.
Here we are 2 years later almost to the day and I still have this random “Brake System Contin. driving possible” message on my 2020 Mini SE. The warning pops up almost daily for a while and then will go quiet for a couple of days.
I have had the both the front and back brake wear sensors replaced. The brake wear sensor wiring was inspected and found to be intact. The brake pads were inspected and were found to have little wear given the use of regenerative braking. It sometimes feels like it is triggered by acceleration or deceleration so I confirmed the brake fluid level is topped off. Other times it will trigger just after rolling from a parked position liked the system is going through some initialization sequence and finding the fault then.
I pulled one code related to brakes but not sure it’s related D3549F - Signal error(data brake system motor control). The code shows up randomly not necessarily related to the warning message.
The car still drives beautifully with only 17k miles on it.
Any thoughts or help on this would be greatly appreciated!
