NeilBlanchard
Ask any ecodriver / hypermiler. Ask Wayne Gerdes, who coined the word hypermiler. Every person on EcoModder.com learns this. With my last ICE car, I averaged ALL YEAR, for 7 years 50%+ over EPA Combined. In my EV's, I have averaged about 5.5 miles / kWh over the whole year. (With our Leaf and Bolt EV, I shift into neutral.)
It is physics: the moving car has stored kinetic energy. All the losses are always there. Comparing coasting to regen, you can do a simple thought experiment - coasting uses the kinetic energy to carry the car forward. The only losses are there no matter what.
If you use regen instead, you lose the portion of energy that regen cannot get back - the motor and charging electronics and battery cells all lose energy. So, by definition regen will lose more energy than coasting.
Rolling resistance and aerodynamic drag are the two main losses. Drivetrain losses are primary, and EV's are the best efficiency drivetrains.
Coasting has an even bigger advantage - you accelerate for less time. Again, a thought experiment:
Accelerate to a certain speed ...
... With a car that cannot coast, you have to still add energy (accelerate gently) all the way up until the time that you need to slow the car. Then use regen to slow the car, and regain some of the energy.
... With a car that coasts by default, you can use the kinetic energy to carry the car forward for some of the time, and you then can add energy only when needed. You can anticipate the stop, and so you can coast while you need to slow the car - and then use regen only when you need to stop the car, and regain some of the energy.
Same distance, very similar average speed - coasting uses significantly less energy because of less acceleration, and less regen needed - so less energy lost.
And, if the stop is for a traffic light, you can coast while you watch the light cycle, and you might be able to time things so that you never have to stop the car - and you then do not have to use very much energy to get the car back up to speed.
