Blew the DCFC fuses
electriceddy
Moderator
Staff member
So I later speculated when my EV stopped charging as I just starting pleasantly dozing off, didn't need to charge just wanted a little rest.
Stumbled out and pulled out the connector ok then tried the other unoccupied one and nothing.
Sort of waking up maybe my new EV ...ICCU?
Then I looked at that DC charger, the display/lights were out. Tried to disconnect from car and no pull out. Had to learn quick how to disconnect manually, easy peasy little knob in back. My guess it will come out ok if the Charger dies and always check before - lesson learned.
Great, I blew the feeder fuse, these guys are not going to be impressed and I had no equivalent replacement in the car.
So much for free DC charging:(
Went into the dealer - "sorry guys it's my fault" ... turns out someone hit a pole a couple of blocks up.
Better luck next time
What went through your mind when the DC charger suddenly shut off, and how did you figure out the problem was actually caused by a power outage from a nearby pole being hit rather than an issue with your EV?
I had a DCFC location do a reset/reboot while I was connected charging, and I thought "uh-oh" while it rebooted. But the charging never stopped, it was just the EVSE session controller that rebooted. After reboot it was sitting at a "start new session" screen but the charging kept going. Eventually I just disconnected and drove away, no idea what the state of the charger was left in. But I never got charged for any of that session.
