Here is a poor layman’s attempt at Clarity Battery 101.
The Li-ion 17 kW traction battery is similar to ones in smaller applications and can be thought of as packaging more of the small cells together to gain higher voltages and capacity. This does mean that now we are talking about lethal Volts/Amperes being present in the car, hence the orange marking on high voltage wiring.
The conditions that affect a Li-ion battery’s useful life in terms of longevity and ability to hold a charge are-
1-extreme charging and discharging rates as in faster than a Level 2 charger or extended very high demand
2-extreme temperature, especially high temps; and extreme temperature swings when fully charged
3-over charging and to a lesser degree remaining at a full charge for extended periods
4-full discharging to zero state of charge (SOC)
5-failure to periodically balance the differences among all the battery cells
Dems da bad news. The good news is that Honda has taken all that battery chemistry and physics into account in designing their battery management system (BMS):
1-Level 1 and Level 2 charging does not approach the rate that will harm our battery packs and the Clarity does not accept any fast charging like dc or super chargers. So no worries here, although a few will argue that Level 1 is less stressful. I think the difference is too small to matter. And normal acceleration is not a problem, although I would avoid repeatedly runs at your local drag strip. Note that the Tesla’s and Leafs have limits as to how often they can dc or super charge on the same trip to protect their batteries. We don’t have to worry about this.
2-With the larger size battery pack and the more rapid charge/discharge cycles, a liquid based cooling system is required and is why sometimes with the car off you may hear a “gurgling” sound as the fluid is circulated to a radiator under the hood. Also sometimes the radiator fan will come on for even more cooling. Unlike the Nissan Leafs that have no active battery cooling, Honda has designed our Claritys to keep their cool. And our Canadian friends even get a battery heater.
3,4-Honda’s BMS appears to have adequately avoided the overcharging and full discharging problems quite well. You will notice that when your EV estimate reaches 0 and HV mode is called on, there are still 2 bars on the battery gauge. This is the buffer that protects the battery from being fully discharged.
What about a buffer to keep the battery from being over charged? Here we have to speculate based on evidence reported on this forum. The most anyone has reported their
EVSE delivered to the car charger is 14.1 to 14.4 kW and assuming the onboard charger (ac to dc converter) is, say, 90% efficient, then only about 12.5 to 13 kW is actually charging the battery.
This means the
usable capacity of the battery is around 73 to 76% of the 17 kW giving a buffer of about 27 to 24% split between top and bottom. This is on par with reports on other EVs and means you never fully charge or discharge the 17 kW battery pack. So no problem here, but some will argue that charging up to only 80% of the useful SOC is beneficial. I think it with the buffer already present that it makes such a small difference as to be unnecessary.
5-The consensus seems to support that the BMS balances the cells at the end of a full charge. So no worries here as long as you periodically charge fully. (Lawyer required info: The manual states to fully charge the car before driving.)
Add to the well designed BMS we have the fact that in California, the same battery pack gets a 10 yr warranty so it must be designed well or Honda would loose a lot of money in warranty replacements. BYW, Honda warrants the battery capacity to stay above 36.6 Ahr. This is about 2/3s of the nominal capacity of 55Ahr your start with. And in 8-10 yrs, I bet battery tech and prices will be dramatically better than now.
So, batterywise, “Don’t worry, be happy”. (Insert Jamaican music here)
PS:I am a molecular biologist and not an electrical engineer, or even a chemistry/physics guy. So I hope the EE experts will add to and/or correct the above which is just my self taught info and layman’s approach to this.
