AndysComputer
Before we got our EV's I was watching YouTube videos and reading blog posts and now we have our Mini and I'm messing around with testing various aspects of it my mind dimly recalled this article on here about the i3:
https://insideevs.com/news/325863/bmw-i3-how-preconditioning-works/
Given the i3 and Mini share the same drivetrain and presumably electronics I was wondering if anyone can confirm my belief on how preconditioning works:
1. If you use the app to turn on the climate, let's say a few minutes before you want to leave, it simply heats the cabin. If plugged in at the time it uses wall power to do so, if not it uses battery power. If plugged in and there is not enough power from the wall, say the level 1 EVSE, it uses what it can from the wall and mixes in a bit of battery power to make up the difference.
2. There is no battery warming function on the i3 or Mini, ie it is not something you can turn on via the app or the in-car screens.
3. If you set a charge window and departure time in the app, the car will preheat the cabin by that time and delay charging the battery such that it finishes charging just before you leave and that charging will create heat in the battery and thus pre-condition it. This is the only mechanism by which the car can heat the battery, as a side effect of charging. It has no dedicated battery heating system or logic.
4. If the car has a full battery then that cannot be heated for your departure time, only the cabin.
I can see no sources to any of this beyond Tom's article so I am assuming it is the battery charging that is in essence preconditioning the battery. This is very different than the Tesla Supercharger preheating which uses battery energy to heat it as you are driving towards a Supercharger via GPS.
Have I understood this correctly?
I ask as I am going to do a range test at 5am tomorrow morning before work as it will be 1 degree above freezing and the battery is currently at 92%. I set the charge window to 8pm to 5am (which is our free electricity period on our plan) and a departure time of 5am. So I am thinking it will start charging probably at around 4am or just after, in order that full charge is reached by 5am along with a warm battery (I don't know how much charging is needed to effectively heat the battery but I assume 45mins worth on L2 is better than nothing) and the cabin is up to temperature. At least I'm hoping this is what happens...
