CuriousGeorge
That was my understanding as well. Has anyone been able to actually do so?You cannot lease a SE in the US.
No. Just threw it out there because it’s interesting. I can’t imagine how many Roadsters are still running, though I suspect any current owners are indeed well-enough-heeled to do the necessary work. Whether or not it’s considered one of the seminal cars in automotive history is debatable, but it certainly is notable and examples are worth preserving.
Anecdotally I have come across an unsettling number of i3 battery warranty complaints online. Batteries with 68-80% SOH. Tesla has sold well over a million Model 3s and I can’t remember any complaints above 5-10% health loss. They also tend to put on vastly more mileage.
I take care of a few off warranty i8s. They are full of annoying an expensive issues.Interesting thanx for that.
Apart from M3's, ev's are pretty thin on the ground here ATM so it will be a good business opportunity to be the first here when the time is right.
I guess the trouble is, apart from pollen filters and brake fluid flushes, there is not so much general maintenance services to make the easyish money on which means these types of business will be less mechanic's and more photocopy technicians.
LOLI take care of a few off warranty i8s. They are full of annoying an expensive issues.
the huge problem with Tesla is not service data/info that’s all open source. It’s being approved to buy parts. They have to see if you are worthy of them. We have done brakes and basic stuff on Model S and 3 because the owners don’t want to deal with Tesla and a 6 week wait. Luckily a supplier of ours keeps brakes etc in stock. We have also done lots of lowering springs on Model 3s. Very very simple car to work on actually
build quality is wonky though. Some cars are literally ziptied together while others won’t be. I removed the frunk liner on a few to change the springs and wiring main harnesses were literally taped in place.
Yesterday when it was about 5 ºF, while driving in green mode with A/C on, my GOM said I had 53 miles left. I turned off A/C and it went to 52 miles. Then I switched from green to mid mode (to get full heat) and the GOM went up to 60 miles!I still laugh at how bad the GOMs are
It’s like tapping on the depth gauge in a submarine movie “bad news” taps on gauge “good news”Yesterday when it was about 5 ºF, while driving in green mode with A/C on, my GOM said I had 53 miles left. I turned off A/C and it went to 52 miles. Then I switched from green to mid mode (to get full heat) and the GOM went up to 60 miles!
Lol perfect.It’s like tapping on the depth gauge in a submarine movie “bad news” taps on gauge “good news”
I think the busyforks was fine for efficiency, but the WLTP numbers are overly inflated leading to inflated real-world disappointment.I should add that I did this drive on full Nordic winter tires, although they were pumped a bit harder than recommended, at 38/35 psi. I’m not sure what tires the two webzines were using.
If you watch thelatebrakeshow Johnny talks about the wide range of WLTP ratings. Based on what I’ve read here and YouTube the Mini SE range is maybe underrated by 20-30% but I guess it’s better to under rate Vs overrate then get suedI think the busyforks was fine for efficiency, but the WLTP numbers are overly inflated leading to inflated real-world disappointment.
Today, the GOM showed 58 miles and my wife (more pessimistic than the GOM) was worried that I'd run out of juice on my 45-mile trip with winter tires. Upon my return, the GOM read 20 miles. Does that mean the GOM was pessimistic before the trip and optimistic afterwards?I still laugh at how bad the GOMs are
The GOM is really pessimistic when you start, based on your last trip. But it seems to recalculate during a trip, so you can see a sort of distance dilation effect, where one GOM mile can be more than five miles of actual distance.Does that mean the GOM was pessimistic before the trip and optimistic afterwards?
No. It would be just as bad. An unrealistic one either way is bad. I seriously don't even look at mine and wish it would just be replaced with battery percentage as an option there vs having that only as one choice at tge bottom.Would it be better for the GOM to be overly-optimistic and run people out of charge or be overly-pessimistic and people get to their destinations but complain about the GOM online?
