RobinBrain
How low does you fuel tank have to go before you fill up? I've only ran it dry once, but have been driving it at half a tank for a while now.
Can you provide more details on your "ran it dry" experience, do you mean ICE would no longer operate and you only had battery power?How low does you fuel tank have to go before you fill up? I've only ran it dry once, but have been driving it at half a tank for a while now.
Thanks, that's what I was looking for. I certainly don't plan to intentionally run out of gas or even get near empty but it's still good to know what the car does in those situations.My wife and I had a bad situation and we ran out of gas once (but the car still had arround 20 miles of electric range). So a few things happened:
1. Low fuel light turned on, and we keep driving until all lines in the gas gauge dissapeared and the HV range showed 0 miles. After that we drove for around 15 more miles.
2. The car was on HV mode so when we run out of gas, the ICE motor stopped and a message appeared in the dashboard: "power system problem"
3. After that, the car kept running on electric mode, and when the electric range dropped to 15 miles the message changed to "power system problem, stop driving when safe"
4. Thanks God, we reach an open gas station when electric range was 8 miles. We put 7.3 gallons on the tank (0.3 more than specified on the manual). After filling up, I turn on charge mode and the engine started normally, then everything back to normal.
I now just fill the gas tank when it warns, just like one would do with a "normal" car knowing that even if the actual fuel in tank is relatively low, the car's range on modest amount of fuel is extraordinary and generally with some EV range to spare.
I wonder what that service costs, how much of a charge EVSE tow trucks provide, and how long does that take? I assume the trucks give only enough of a charge to get the range-challenged BEV driver to an EVSE, but that could take a significant amount of time--certainly longer than it takes to tow a car to a repair shop.Glad to hear that tow trucks these days are equipped with EV charge cords as well as fuel.....
