Atkinson, thank you for the information in your post. Could you point us to the source? I am especially interested in the "fixed throttle" aspect. I will look to see if the throttle opening data stream works on my OBDII scanner (or if the code from a Honda Accord Hybrid works)
Before the October update, I think your description of the power flow and engine coupling/decoupling is what I experienced. After the update, the behavior is different for me. If the engine is coupled, say at 70 mph, and I need to accelerate a bit or increase the power to climb even a slight grade, the engine immediately decouples and the rpm engine rpm increases (from about 2500 rpm when coupled at 70 mph) to in the range of 3400 rpm to 3800 rpm. When I settle back to an an even grade and even speed, say 70 mph, it takes a while for the engine to couple again. Also, when I release the accelerator pedal even the slightest amount to go down a grade or to slow, the engine immediately decouples. If the grade continues or if I stay slowing, the engine turns off until I speed up or stay at a slower speed for a while. Even if the speed is above 47 mph or so, it takes quite a while for the engine to couple again. Before the update, the engine usually stayed coupled at these times.
I posted earlier that I thought that the engine was louder after the update. I think this may be because the no load rpm is now 1500 rpm while it was lower previously (about 1200 rpm or lower if I recall correctly). BTW, I liked our Clarity better at highway speeds in HV mode before the update. The EV mode around town does not seem to have changed after the update.
LeoP
LeoP
