I’m having the same experience as
@David Towle. Except for when in regen, hard acceleration, and steep hills when it obviously has to be off, I can’t see any rhyme or reason when it decides to be in or out of gear mode. Some trips it’s a lot and some not much even with speed and terrain similar.
KentuckyKen
Just a rehash of data collection efforts for those who are new'ish forum members. Thought it might add to the conversation.
From a post made back in March 2019...
..."Engine clutch mechanism engages as I expect on all roads where speed limit is ~45 or greater. When
maintaining 45 mph speed or greater...it goes off when climbing noticeable grade and when descending a similar grade. Otherwise...stays on majority of the time when
maintaining speed. Very pleased with performance of the engine clutch"...
The data collected to date points to a certain RPM range where the clutch will engage/disengage at a given speed. As posted several times...as an example...clutch engagement in the Clarity I drive comes on like clock work at 45 mph/~1625 RPM when desired speed is reached and I
maintain that speed and RPM. When I say like clock work...I mean in the literal sense.
The data also demonstrates when I am at speed (ie) 45 mph...if the RPM is greater than/less than 3% of the threshold (ie) ~1625...then the gear icon will either disengage or not engage.
Every time I notice the the clutch disengage...RPM's have increased or decreased past the 3% threshold whilst
maintaining speed. Uphill more power thus higher RPM's...downhill less power even goes into EV mode.
The data collected also indicates a strong correlation of RPM/clutch engagement at 5 mph increments up to 65 mph. (ie) 50 mph clutch engagement at ~1800 rpm for example. Very predicable at given speed and RPM. Same 3% threshold applies to all speeds = 3% higher/lower RPMs = clutch disengagement or won't engage.
I don't have the opportunity to drive on flat ground often so my experiences are rolling to mountainous roads. I have no real idea how the Clarity operates in south Florida or West Texas on pseudo flat ground.
At the end of the day..the clutch engagement remains predicable based on speed/RPM thresholds for the Clarity. The question is why does the Clarity increase/decrease RPM's for no apparent reason when maintaining speed on the same stretch of road? Under similar conditions? Generator? Needs mo power? Dunno.
Scan Gauge II works great for the correlations. The Autel Maxi AP200 provides interesting data as it includes three RPM levels...Engine RPM...Motor RPM...Generator RPM. Still trying to cipher the what and the why on the differences...may be nothing. Interesting thing is when the Clarity is on the move...each of the above display significantly different RPM numbers.
It would be great if mo folks would collect mo RPM data so we can collectively hone in on this issue.
Hope this helps.
