Another BMS recall for the Kona
Electric Rich
I heard wind of another BMS recall and sure enough, after checking my Vin# with Hyundai, they want to run some diagnostics on it. 2019 Kona EV
Checking for battery cell damage and updating BMS software I think. Sounds like the current BMS S/W may lead to over heating/charging and cause a fire in super rare cases.
I heard wind of another BMS recall...
It applies to all 1st-gen Konas (104,011 worldwide acording to a German source) and the Ioniq 38, but it appears not the Ioniq 28.
The 2nd-gen Kona is not affected.
Like others it's been worded for the worse-case scenario. It's the same procedure as every other BMS update we've had, meaning they may stumble upon a few battery packs that are out of spec and require replacement. The update was issued in parts of Europe from January 2026 and is just now being rolled out in Australasia as you've noted. The reason for the delay could be as simple as Hyundai not wanting to overload their service portal, or that the update needs to be processed by regional vehicle safety regulators.
The basis for the recall as best as I can determine is that Hyundai are reducing the tolerance needed for a dash warning of either abnormal cell-group voltage imbalance or high battery module temperature. It's not clear to me yet that this was strictly a voluntary action on the part of Hyundai, but it is noted that it was not due to any catastrophic events.
Along with care and feeding of the batteries to maximize their longevity, there is a complementary activity that we should perhaps be performing regularly: that of properly exercising the Battery Management System (BMS).
There are at least two BMS functions that we can help: Cell Balance and State of Charge (SoC) calibration.
Can someone provide links to where specifically these two topics are discussed for our Kona? TIA
For example, cell balancing (a very slow process done in small increments) on my i-MiEV only occurs at the top, after the battery shows it's fully charged (16/16 bars) and before it stops charging by itself. IIRC my old 2013 Tesla does slow top balancing above 93%SoC, whereas modern Teslas and my homebrew solar battery BMS have continuous balancing independent of SoC. On my i-MiEV the SoC calibration is done by discharging the battery down to two bars (2/16) and then letting it slowly fully charge undisturbed until it stops charging.
There's been little discussion of any substance unfortunately. I've mentioned a few times in the past that balancing after charging on the 1st-gen Kona can be witnessed using a BM2 as the BMS runs entirely off the 12V battery when the traction battery is offline.
I've seen this after every home charge where I use a 2kW EVSE exclusively. This was one of the longest durations at 4.5 hours. it appears to be programming the individual cell-group loads every half hour to suit the corrections needed, then sleeping in-between.
I've only been made aware recently that it also likely takes place while charging. There's an interesting article about a Ioniq 28 owner who was focused on getting the best possible range at 100% charge, which requires the highest possible pack voltage be obtained when charging stops. In a nutshell he found that balancing was too slow to keep up while on a 7 kW rate. Slower charge rates generally resulted in higher final pack voltages. This voltage variation (of about 5 volts) had been noted among Kona many years ago but no one even recognised (or cared) that it affects range slightly when you've already got 480+ km.
The concern I have relevant to this thread regarding the BMS update is that with (3) cells hard-wired in parallel per series group it's exceedingly difficult to detect a single failing cell. My original (Sept-2018) pack always had one particular cell-group low by the (minimum readable) 0.02 V (which I'll assume means it could be as bad as 0.039 V since 0.04 V is the next readout increment).
I only recognised later that the fact that one group could never could achieve a closer balance was the unmistakable sign that one cell was continually self-discharging at a very low rate. The 'MIN cell' value was always #54. I monitored that situation periodically for four years and it never got any worse but I really should have asked Hyundai for my replacement battery sooner. The new pack has always had perfect (<0.02) balance.
This new BMS update needs to look for trends like this to spot problems. The 2nd-gen Kona and Niro has only one cell per group which was a smart move to side-step this issue.
Hi! The Official German source is KBA=
Hyundai France said nothing until this morning: I have now a new recall for my Kona 2019
I'll have the BMS updated, Hyundai said.
My 2022kona i booked in for this on monday 20/04/26, i have been told it takes 2 hrs here in Perth Australia, the check no is 61D004
  • Like
Reactions: Zem
I have a 1st gen 2019 64 kwh in the US and there is no recall on my vin number.
I have an Australian 2022 Highlander long range (64kWh). 61D004 update performed last week. Took about 2 hours. So far only thing I’ve noticed is that all the BMS stats have been reset. I’m currently charging to 100% on the granny charger.
I’ve noticed in the past that at about 95% that the charge rate drops for a while. I assume it’s cell balancing.
My last 100% charge gave me 566km on the GOM, city driving.
Car Scanner showed no deviations before or after the update.
Hi had mine done last week, have notced the the charging losses are now only %7 not nearly %20 as before and reported by Byorn nyland
At every prior BMS update we've had, all cumulative battery history has been reset. That also means the SoH goes back to 100% until its been re-evaluated.
The update is not going to change hardware charging losses but any BMS data used to assess that will be questionable until it settles down.
Here are my pre- and post-update numbers for the last update, issued Oct 2023. The SoC(bms) value, therefore also SoC(display), appears incorrect as I recorded these just after leaving the dealer's shop.
well i am not looking at what the car says just what my Zappi says has been used to charge the car, so 14% is 8.96kwh remaining
89% is + 48 kw used to charge. it was 51.5 kw so 7% ac charging loss, and the the main battery charger is software driven an controlled for voltage control
Wish I'd known of this resetting of BMS cumulative data before I had my BMS update done a few weeks ago. I've since checked Car Scanner and, sure enough, SOH is now 100%, No. of quick charging is zero and No. of standard charging is a handful.
I presume that info is gone forever?
Fortunately, I noted my SOH of 97.3% in early March. But is that even reliable if the vehicle has had other BMS update prior to my purchase?
Also, is this SOH figure the prime determinant used for the battery warranty claims at or before 8 years/160,000km?
If so, have all our battery warranties been 'diluted' by these data resets during BMS updates?
And does this also reduce the value of EV Battery Condition Reports by motoring clubs etc. as I believe from their marketing, that they take into account cumulative fast/slow charge nos./energy data, as well as SOH from the BMS?
TIA.
Yes, it is.
Sure. The SoH will be re-evaluated over kms driven and probably go back to roughly where it was. But the distance or time required is not known. Could be weeks or months.
Yes, but no one has ever reported making a claim. The warranty trigger level is 70% SoH.
There's no evidence of that even being a thing, see below.
No. As best as is known all the BMS update does is adjust error trip levels.
I have used Car Scanner and EV Spy many times to look at the voltages and I have 2 cells that are always 20mV low.
I have performed the cell voltage scan at multiple SoC when car was static as well as while charging and driving and have never detected anything other than these two cells reporting 20mV low.
Never better and never worse (except of course during charging and driving where the scanner can't update fast enough to deal with the dynamic situation).
If it is always the same 2 cells that are low and always by a constant 20mV, I see no evidence that any cell balancing is occuring.
Anybody have objective evidence of the BMS balancing cells?
Where is the manufacturer's statement that the BMS balances cells?
Of course it balances the cells, lol! You'd have major problems very quickly if it didn't. Every electrical battery made up of lithium-ion cells wired in series needs a balancing function.
0.02 OCV is within the allowable safe tolerance but not an encouraging sign as it means those relevant cells have a very slight internal short.
If this is not a Kona EV you're referring to you might want to post in the relevant forum.
Balancing on the Kona is readily visible on graphs of 12V system voltage in the hours after charging the traction battery.
Every battery with series connected cells should have cells with very tightly matched characteristics.
How do you know that the spikes in your chart represent cell balancing versus some other events - were you monitoring cell voltages and could see signs of low cells having their voltages raised?
well the traction battery is not balanced by the 12 volt battery ever, its the other way round the traction battery charges the 12 volt battery as the car is driven and at 4 hr time intervals when parked as well or if the 12volt battery go,s below 13.6 volts at any time,
So the traction battery is only balanced when the car is on Charge using AC or DC charging and it only happens if the battery is charged past 85%
