2023 SE Countryman Floor Mats?
  • Thread starter Thread starter AlexGoes
  • Replies Replies 14
  • Views Views 3K
AlexGoes
Hello. I have combed through posts and cannot find floor mat recommendations for the 2023 MINI Cooper SE **Countryman**.
- WeatherTech makes laser-cut versions for the 2022 SE Countryman, but reviewers state that the pegs/holes (to hold the mats in place) aren’t measured correctly.
- The 3D Kagu All-Weather Custom Fit Floor Liners are available for model year 2022, but they don’t specify SE.
Do 2022 SE Countryman floor mats fit 2023 models? Do combustion engine Countryman floor mats fit the SE/PHEV models?
I can attest that the Weathertech floor mats fit well in my 2015 Countryman and the peg/holes are in the right place but the pegs themselves are a poor design. They won't stay in place and are harder than hell to insert. Looking at the pictures of the 2022 SE mats -no 2023s are listed - the pegs look the same. I have seen Weathertech mats for other makes and the retention system is much better - not sure why they went with the peg design they did for the Mini
I have WeatherTech mats in my other cars, and I like them very much, but my SE has my first set of 3D Kagu mats, and so far they are superior in almost every way. The back is a kind of hook material that grips the car’s moquette tenaciously, while the front is textured and patterned like a textile or weave, and doesn’t look dirty after months of use — unlike most black thermoplastic, rubber, and polyurethane mats that get scuffed the moment you step in.
Thanks! We have had them for years in our other car and we’re surprised by the reviews on the MINI version.
I had read others’ positive remarks on these mats in other posts. I was all set to order them and then noticed their fit comment that the mats don’t fit the plug-in hybrid.
Is the backseat different in the Countryman SE vs the ICE models? It doesn't have that warning for just the fronts.
Our salesperson noted that the SE rear seats do not move forward and backward as in the ICE. In addition, the seats sit a bit higher due to the battery. Additionally, the MINI floor mat part numbers are all the same for 2022 vs 2023 as well as SE vs ICE. Given those data points, my guess is that 3D Kagu rear center piece does not work for the SE.
I ended up ordering the full set of 3D Kagu mats. My hope is that the mats work with the possible exception of the rear center piece. I will report back.
If you don’t often ride four-up, and unlike my OCD, yours doesn’t kick in too easily, you could use the 3D mats in front, and more mundane mats in the rear, just to protect the carpet when you have the occasional passengers back there.
The Kagu mats for the F56 don’t go over the “tunnel,” but I believe their site shows a separate rear tunnel mat for the F60, unlike Weathertech’s one-piece “over the hump” design.
My OCD runs as fast as a MINI JCW Hardtop.
