Wreckless117
Continuing my quest to rid this car of non-LED bulbs and improve output, I have replaced the boot light and the glove box light for under $10.
The glove box was super easy as that was just a simple swap. Output and color is perfect.
The boot light on the other hand was a bit more complicated as I wanted as much directed light as possible since this is not a closed reflector housing (another oversight by manufacturers). Why don't they think we wouldn't want as much light as possible in the boot? Shoot a light on both sides would be preferred!
So I went with an LED board to direct the light one direction to maximize luminosity. Unfortunately this requires a bit of modification to both the LED board and the housing to make it fit, so would not recommend if your not handy, or afraid of having to purchase another housing if you screw up.
I am satisfied with the results.
Now I just need to figure out a hardwired solution for the charging port....
