2019 Kona max charge rate of 175 kW?
Thomas Mackay
Went to an Electrify America charger today, one with a fancy label that says 350kW! (yes I realize the Kona cannot do that high a rate. BUT, my receipt says the rate maxed out at 175kW.... Thats about 100 kW's more than the Kona's advertised max charge rate? Right? Am I crazy? After I plugged it in, I sat and watched the rate rise to 70 kW's then I walked away from the car, so I did not visually confirm what the car actually did.
Both my EA receipt and my EA account both say 175. Mind Blown.
Yeah, very strange. Probably a glitch in the EA software. It took you 32 minutes to charge 32kwh, though. So if you had a charge rate of 175kw it wouldn't have taken that long unless it was for only a couple seconds.
BTW the Kona can charge at 150kW. At least regenerative braking. Not CCS, though. [emoji6]
So even that isn't fast enough.
Well, since EA charges for Kwh delivered, it really doesn't make any difference. Hope you were charging with the membership rate of $0.31 per Kwh. Maybe the bug is a throwback from when you were put in categories of max charge rate? I don't recall a 175 group.
