Boogaloo
And in reference to all of the above or below? Posts. I purport that the typical dealer is the last place to take a Bolt based on the fire hoo hagm directly, the Bolt EV concierge 8667905600
Good luck
Good luck
I have a 2020 that does the same thing. Going to the dealer thus morn. Will post results!We purchased our 2017 Bolt EV in early June 2017 and now have about 5000 miles on it. So far, we've been very pleased with the car. However, a few months ago, the car started to make a rapid tapping sound when the door is opened and the car started. At first, the sound was very intermittent and went away with a brief tap on the brake pedal. Now it's more frequent and some times comes on even while driving, then goes away. I could easily trace the sound to the brake master cylinder.
We took the car to a Chevy dealer who confirmed that the sound was not normal. They could not determine what the cause was, so they recorded the sound and contacted GM. The latest from GM is that they will be sending out a part called an "I Brake". Neither the service guy at our local Chevy dealer, nor the certified Bolt technician have heard of such a part, and I couldn't find anything online to identify the part either.
If anyone in Boltsville has had a similar issue, or knows what an I Brake is, I would appreciate you sharing this with the group and myself.
2020 bolt similar prob software fixThe "Tapping" / Rapid Clicking sound (after unlocking the driver's door (not sure if it does this on the other doors, as there's just me), low speeds (stops when pressing the Brake pedal) and after turning the car Off), IS NOT limited to the 2017 Bolt.
My 2020 Premier started this last Friday. And, today, was the earliest that I was able to get an appointment with my local dealership (had an online Appointment for Wed morning, but I got a text saying that the online system is messed up, and the earliest was Thursday at 09:00).
Sadly, though not unexpected, the Diagnostics check turned up, zilch! And, the tech had 0 experience with this happening.
But fortunately, the dealership's Service Department is connected to other dealership service departments. And, within about 20 minutes,, the problem per Service Bulletin 20-NA-170, Program Brake Booster Cont ROL Module, was fixed.
