20+ kWh to charge the battery
The Volt has a coolant TMS similar to the Clarity.
I guess I misunderstood their comment to mean cabin air temperature when they presumably meant ambient temperature.
The Volt's battery heating/ cooling system does include a heat exchanger which allows excessive heat to be removed by the car's air conditioner system.
So not using cabin air but using the same freon loop as cabin air.
There is no AC/freon cooling the battery. Kentucky Ken is correct in that it is a radiator based cooling loop. See the attachment "Integrated Cooling System for Underfloor High Voltage Devices in PHEV" on post number 145 of the
Honda Service Express Bulletins for 2018 Clarity PHEV:
https://www.insideevsforum.com/comm...-for-2018-clarity-phev.2183/page-8#post-50910
It should be noted that if it is too hot, the Electric Powertrain Temperature Controlling System will not actively cool the battery-the coolant will bypass it, leaving the battery to its own heat rejection as the only way of moderating temperatures. As shown in the diagrams below, calling it a cooling system is a misnomer-it is moreso what I like to call a "Out of Specification Temperature Avoidance System". The system tries to keep the battery between 25C and 35C (77F to 95F) but if it can't the coolant will bypass the battery. It is primarily designed to work at the top of the temp range although I think a lot more could be done to bring the temp up in the winter (that's an entirely different post).
So I would be careful. The battery probably went over the temp range while you were driving. The DC-DC converter and on board charger can get very hot while driving or charging. In that case the coolant will bypass the battery. The system can only bring the temperature down 12K (lets round that conversion to 22F) versus ambient so if the DC-DC or on board charger were above 117 (the highest I have seen on my Scangauge is 120F) then there is no battery cooling taking place. When you plugged it in, it was most likely not charging the battery but bringing the on board charger and DC-DC converter down to inside the temp target range. Once the coolant got the temps down charging would start but it would cycle on and off as temps got to hot in your 100F garage. Like others have said wait as many hours as you can before charging the battery after a long hot drive.
@AnthonyW, my hero!
Superman ain’t got nothing on you!
I’m picturing you in in a Superman outfit but with a C instead of the S.
Up in the sky, it’s a bird, it’s a plane, no it’s @AnthonyW dispensing more info about the Clarity’s secret inner workings than all the dealerships combined!
PS: I can confirm that all 3 cooling loops are the identical Honda glycol based aqueous coolant. I accessed the coolant recovery tank under the front cover when I had it off to install an air horn. It’s the the same color and smell as the other two visible recovery tanks under the hood. So the battery coolant is not some high tech expensive non conducting fluid as some have speculated.
My thanks to KKen and AnthonyW for getting this information! I am constantly amazed at the depth of collective technical knowledge on this forum. I read lots of technical specs on both the Volt and Clarity before buying, and obviously I confounded these two in my mind.
It seems like Honda was not engineering for maximum battery life if they didn't allow AC cooling of the battery. Operation at high battery temperatures is a big factor in battery life, and it would be easy to get into the high temperature regime on these 95F days.
The battery teardown video that was posted a bit ago showed that the battery coolant runs through some metal plates that are in contact with the batteries, but no coolant actually touches a battery or electrical component.
I think that's the case with every EV liquid battery cooling system. They all run a water/glycol mix thru the battery pack, either in small tubes imbedded in flat metal plates (like the Volt) or in ribbon-like tubes that weave in and out of the battery cells (like Tesla).
While it's reasonable and plausible to argue that Honda's battery cooling system is inferior because it doesn't include a heat exchanger which allows the A/C to remove excessive heat from the system, that may be jumping to a conclusion. It's possible that Honda uses battery cell chemistry which is more resistant to heat, and it's possible that Honda has engineered the water/glycol cooling with sufficient capacity for heat exchange that it will keep the batteries within normal operating temperature even when it's hot outside. A two-speed, high capacity water pump to keep the coolant moving faster when needed, and a sizable radiator, may be all that's needed to eliminate the need for a heat exchanger connection to the A/C.
An AC compressor essentially squeezes heat out of the system by compressing the refrigerant to raise its temperature so that the heat can be conducted away at a much higher rate. It is a really effective way to cool but the compressor uses a lot of power as evidenced by the power drain caused by our home and auto air conditioners. Especially if the compressor is running just to cool the battery, but even if it is used while cabin AC is running this will reduce the capacity for cooling the cabin so the occupants will likely run the cabin AC harder to compensate.
You could be right that Honda took a different route and made efforts in other ways to provide adequate cooling without using a compressor, thus saving power overall. It could be argued that maybe Volt was able to "shortchange" some aspects of battery cooling since they knew that they would be using a compressor to remove excessive heat when needed. Not saying they did but like you said we really don't know. In the end a cooling system comes down to cost, power, space required, and cooling efficiency. A car maker has to juggle all of those to come up with their particular strategy.
I'll add one more: reliability.
To me, the two biggest cons of liquid cooling are complexity and reliability. The Volt is known for bricking and stranding drivers due to EV powertrain cooling issues; even something as minor a fluid level sensor can do it. A major issue that can happen, although rare, is an evaporator gets punctured by a rock and loses coolant. That's not covered by the warranty BTW. I haven't looked at the Clarity's front end design closely yet to see if it's "good enough" or if adding a mesh rock guard is prudent but since mine is going to become a highway commuter, I will definitely check.
It's possible that Honda uses battery cell chemistry which is more resistant to heat...
I should have written more tolerant of heat, not resistant to heat.
I'm regretting recommending to the moderators here to cut off editing posts after ~2 hours. I'm enjoying the ability, on the InsideEVs News site, of editing out an error in my comments that I spot the next day.
And the big flaw in my argument, which I'm surprised nobody pointed out, is that no matter how big the battery pack liquid cooling system's radiator is, it's not gonna cool the battery down below the ambient temperature. If it's 114° in the shade outside, then the battery pack is gonna be too hot for li-ion batteries no matter how fast the coolant is flowing thru the pack.
The more I think about it, the more I think that yeah, Honda and every other EV maker ought to put in a heat exchanger that allows the A/C refrigerant fluid to suck heat out of the battery coolant when the latter gets too hot.
