The worst brake pads on SE making wheels dirty without using brakes so often?
Discussion in 'Cooper SE' started by Rexsio, Sep 17, 2022.
  1. MrSnrub
    MrSnrub Well-Known Member
    I’ll check the PN when I get back to work but they should be the same
    we use akebono as they are low dust
  3. Hatch
    Hatch Active Member
    PA
    If these are really the pictures of the rear pads, then these are the correct ones. I just ordered them from Amazon. I'm having a hard time finding what look like correct Akebono for the fronts. But the rears are the most critical because of this dust issue.
    https://www.fcpeuro.com/products/bmw-mini-brake-pad-set-akebono-eur1762
    https://www.amazon.com/gp/product/B07ZLDJDSP
    If you look under the fitment tab on the Fcpeuro link, it shows Cooper SE.
    I'm really committed to finding Akebonos because i have them on our R53. It went from major dust on the wheels to practically zero.
  4. Louis W
    Louis W Member
    What about Pelican Parts? They list a couple different options, including Akebonos: https://www.pelicanparts.com/catalog/SuperCat/13459/MIN_13459_BRKPAD_pg1_brake-pads.htm
    Their vehicle selector only goes up to 2021, but if the grid on MiniMania is accurate, then pads for all SE model years are the same: https://www.minimania.com/part/G3NMB2210/Mini-Cooper-Se-Front-Brake-Pads-Oem-Gen3-F56-Electric-Hardtop
  5. Rexsio
    Rexsio Well-Known Member
  6. Hatch
    Hatch Active Member
    PA
    Pelican agrees that Akebono EUR 1762 is correct for the rear, so that's a good sign. No Akebono fronts however.
    I'm going to get the rears figured out first, then try to find fronts. This is the next Akebono front set that looks promising. I wish i would have taken a picture of the front pads when i had them out - but this picture looks the same as i remember when i had the fronts out.
    https://www.fcpeuro.com/products/mini-brake-pad-set-front-cooper-eur1308#fitment
  8. pictsidhe
    pictsidhe Well-Known Member
    How well did they work on your R53?
    I went to 294mm R56 front brakes on my R53, Audi 38mm piston calipers on the back and EBC redstuff pads all round. Dust not too bad after bedding in and they are peel-your-face-off-the-windscreen stopping power. Huge improvement on stock
  9. MrSnrub
    Pelican, ECS, Turner. All the same company
  10. Hatch
    Hatch Active Member
    PA
    I wouldn't say they stop better than stock, so not as much stopping power than the EBC. I don't lean on the brakes too much, but even so the stock pads left black dust on my polished aluminum wheels after just short rides. It was crazy.
  11. CuriousGeorge
    So if you replace the OEM pads with something that differs significantly in friction, would that mess with the blending of the regenerative and conventional brakes?
  13. Rexsio
    That is a big question onEV SE bc ceramic pads draw less heat,more heat remains in the rotor, which can cause rotor warping .Metallic brake pads draw more heat and hold it longer than ceramics , but with benefit of keeping the rotors cooler that’s why our wheels so dirty bc BMW don’t want to over heat rotors with regen braking
    Puppethead likes this.
  14. Rexsio
    I m slow with a change a pads but I do when you come up with right staff
  15. insightman
    That is an interesting question. I believe the only time the SE performs any "blending" of regen and friction braking is when it's simulating regen braking because the battery is fully charged. Otherwise, you control the blending with your foot.
  16. Hatch
    Hatch Active Member
    PA
    My theory is the friction difference isn't significant enough for the car to notice or to feel any different to the driver. That goes for DSC operation also, which really is what is causing the dust, right?
  17. pictsidhe
    In theory, theory and practice are the same, in practice, they aren't.
    Doing both a front and rear friction upgrade will not make too much difference. I suspect the car is smart enough to adjust for that, people fit different pads and things vary. Unbalancing the factory friction will affect braking as the car can't change the braking ratio.
    You can see this with people putting monster front brakes on a car and then wondering why their stopping distance increased.
    I was about to order some EBCs, until I saw the unbalanced frictions. EBC red are GG. I'm not unhappy with the braking of my SE, just the dust.
    The lack of aftermarket listings could well be down to the unbalanced friction coefficients. The physical fitment appears to be f56 Justa front, f54/f60 rear. No shortage of those pads on the market.
    I think it would be prudent to at least ask your preferred pad manufacturer.
  18. Hatch
    Hatch Active Member
    PA
    SUCCESS - EUR1762 is the correct Akebono part number for the rear brake pads. I just installed them, bedded them in, and drove around a little bit.
    Louis W likes this.
  19. Hatch
    Hatch Active Member
    PA
    Oops.. I just looked it up and Akebonos do NOT need bedding in. Recommended procedure is try to drive with moderate braking for 400 - 500 miles if possible. I should be ok. I just stopped hard a few times. But DON'T do that!
    ghost likes this.
  20. Rexsio
    Keep as informed how they doing dust wise bc braking should not make any difference . Was a problem to install them ? bc electric brakes in rear they are thinner as on my Subaru they are 9 mm which is thin for now reasons as I change them last week I know the size i change my brakes pads for 50 years myself .If you look for front look for BMW I 3 they should be the same on SE front and rear bc a I3 is on a road for 8 years and after market Acebono or EB is making them for electric crub . You only a one did this I’m a next one bc I do this in my garage myself and tired cleaning my wheels .Thank you for all information.
  21. Rexsio
    Don’t worry as long your rotors with low milage nice and clean without any groves you don’t need to brake pads in ! just drive as you need and tell us how is a dust difference on factory cheep brake pads ?
  22. Hatch
    Hatch Active Member
    PA
    The rear SE pads are pretty darn thick. I didn't measure them. They were among the easier pads i've ever installed. The passenger side has the brake sensor wire. I just popped out the wire from two retainer brackets to give a little more slack, so i could re-attach the sensor to the new (inner) pad.
    Oh and don't forget the bimmerlink app + OBDII adapter, so you can put the E-brake in service mode. I imagine i could have done without that, since the pads were new. But if your pads are worn, just releasing the E-brake might not allow you to fit newer thicker pads in.
    The stopping seemed fine, since i mistakenly hit the brakes pretty hard a few times. It's my wife's car and she won't be driving it much. However, i plan on driving it once a week or so - 50 miles round trip to work. The car is so new that we didn't have brake dust. So i will never have the pleasure of dealing with that.
    I did order the EUR1308 pads from Amazon and they are supposed to be here tonight. So i'm hoping to put them on the front tonight or tomorrow.
  23. Louis W
    Louis W Member
    On the front brakes, when I search for the BMW part number 34106884263 from the Pelican Parts listing (https://www.pelicanparts.com/More_Info/34106884263.htm), I find some references to the BMW 2-series F45, which was never offered in the US. Quality aftermarket options seem to be slim pickings.
    For my part, I really liked the Carbotech 1521 pads on my R53 Mini. They took some getting used to initially. Initially they aren't as grabby as stock, but the feel was linear and they were practically dust-free. I emailed Carbotech to see if they offer something for the F56 or SE. Last resort, they'll take expended pads and rebuild them with whatever compound you want. I'm sure it's not cheap though.
