Mike's wife's monthly Kona EV efficiency report
Discussion in 'Hyundai Kona Electric' started by navguy12, Aug 30, 2020.
  1. navguy12
    navguy12 Well-Known Member
    Results for Nov 2023:
    Operating costs this month:
    Summary costs as of 30 Nov 2023:
    Total operating costs, per km (total costs minus capex costs):
    $3.3761 - $2.9897 = $0.3864/km
    Ferenc Jakab and JoeS like this.
  2. navguy12
    Results for Dec 2023:
    Summary costs as of 31 Dec 2023:
    $3.3238 - $2.9414 = $0.3824/km
    Lars likes this.
  3. Happy 2024 to all.
    Here is my year end summary in a nutshell.
    Distance driven in 2023: 17,997km
    Cost of fuel (electricity): C$431.82 (including 11 DC charging sessions!)
    Cost per 100km: C$2.40
    Total other costs: C$1.268.81
    - 2 cabin air filters (2x48.53ea) C$97.06)
    - 48,000km service with break check @ independent service C$50.83
    - 60,000km Service1 C$94.92 (to maintain warranty - in case)
    - a set of Nokian WHR4 all weather tires C$1,029
    This was painful. At 60,000km on the tires maybe I could have used the old set of same for an other winter. The guys at KalTire were just as undecided. With everything going up in price I decided bite the 'bullet' now.
    I figured that driving ~18,000km in my old Prius with 4l/100km, @$1.50/l would have cost me $1,080, just for gas.
    I had my blue coolant replaced and the heat pump compressor replaced, both under warranty.
    An other observation. I never paid any attention to my monthly Bluelink report before. But for November it shows Total Power Consumption 1,482Wh, Motor Consumption 1,240Wh.
    Regenerated Power 611Wh - that is just below 50% of the motor consumption!
    Checked previous months and the reports are pretty consistent. Wow!
    Cheers
  4. navguy12
    Please let us know how those all weather tires work out for you this winter.
    I’m hoping by the time the current tires age out, the all weather tires will have improved enough that the insurance industry treats them as it does with current winter tires, by providing a discount.
    The whole swapping out a set every six months is getting old. ;)
  5. I am driving on Nokian WRG4 tires for years. Had them on my 2016 Prius for 4 years before traded it for my Kona. So here is my assessment. They work very well for our use in snow, in slush on wet or dry roads. We are retired and 90% of our driving is in and around town. So we have generally plowed roads, but also sometimes ice. Other than that I find the WRG4 a bit noisy on the Kona. They lasted longer on the Prius but EVs are heavy. According to a tire design engineer from Michelin, tires on EVs tend to last 30% less than on ICE cars. The torque and weight is hard on them. The driving style makes a huge difference! There are newer designs now, Michelin Cross Climate comes to mind, but there are others too.
    However, if you are a winter sport enthusiast, or going to the cottage regardless of the season or weather, all season tyres will not replace a good winter tire.
    I hope this helps.
    navguy12 likes this.
  6. Paul K
    Paul K Active Member
    There is a Goodyear plant not far from where I live which re-vitalized the local economy of the small town of Napanee Ontario so I decided I'd get a set of Goodyear winter tires for my 2016 Leaf and kept them for my 2018. They are now 7 years old and have plenty of tread left. However, they are now developing fine cracks in the sidewalls so it's probably time to go. They have actually outlasted the summer tires which must be replaced at the end of this winter. And I might add that they are mounted for 5 months of the year and have more mileage than the Ecopia originals.
    Sadly,I think the sidewall cracking may have been a result of under inflation. The tire installers inflate to the correct pressure in the nice warm shop. The pressure drop in mid winter cold causes them to go below critical. Inflated to 36psi in the shop they will drop to around 26psi in the deepest cold. At first I had cheaped out and not bought the pressure sensors for my winter rims and just ignored the tire pressure light for the winter. Big mistake as a pot hole slightly bent a rim enough to cause a slow leak.
  7. navguy12
    In both our vehicles, I always have the pressure set about 5 PSI above the placard figure to deal with the temperature drop from the garage temperature.
    Lars likes this.
  8. Good point. I keep my tires generally 1PSI above the recommended pressure. Winter time higher for reasons above. 5 LBS maybe too high?
  9. navguy12
    It’s a practice I’ve used for the past four decades and so far, so good.
  10. hobbit
    hobbit Well-Known Member
    Placard pressure is something like 36 psi, which is unacceptably soft and leads to tread-edge wear and
    other problems folks have noted. Sidewall is usually 51. I run mine at 60, like I did in the Prius for years
    too. Rolls like a bicycle, tracks like rails, does fine in sloppy conditions. The hypermiler community [and
    some police organizations] have known about this for a long time, but it never really caught on mainstream.
    With modern car tire construction the perceived "overpressure" is perfectly safe long-term.
    _H*
    JoeS, Lars and navguy12 like this.
  11. I like the idea of over inflation still, I find running a tire over the factory recommendation too extreme for my taste. Also, higher the tire pressure the harder is the ride. Kona with the short wheel base is already a bit on the rough side - after my Prius.
  12. navguy12
    Results for Jan 2024:
    Summary costs as of 31 Jan 2024:
    $3.2968 - $2.9167 = $0.3801/km
  13. navguy12
    Results for Feb 2024:
    Summary costs as of 29 Feb 2024:
    $3.2629 - $2.8847 = $0.3782/km
    JoeS and electriceddy like this.
  14. navguy12
    Results for Mar 2024:
    Summary costs as of 31 Mar 2024:
    $3.2142 - $2.8408 = $0.3734/km
    JoeS, John Lumsden and electriceddy like this.
  15. I notice the insurance portion seems to be the major cost. Out here there is a distance discount. It used to be 5K kms to qualify, but has been revised to 10K kms per year. The less mileage, the more the discount. With those low kms ~ 5230/year, I would think that would be something worth investigating;).
  16. navguy12
    The first two years of insurance was with our legacy insurers; once we made the move to the Ottawa area we went with CAA and now she pays about $500 a year.
  17. navguy12
    Results for May 2024:
    Summary costs as of 31 May 2024
    $3.1173 - $2.7510 = $0.3663/km
    Sorry I forgot to post the April 2024 data.
    Wildeyed likes this.
  18. I've uploaded my summary of costs for my 2022 Kona purchased May 2022, cost AUD$ 57000 approx. I'm not the best chart setter outerer so hope you can follow and make use of it. Thank you to navguy12.
  19. navguy12
    So it looks like just shy of $AUD 4.3 cents per km (about $CAD 3.9 cents per km).
    Your hydro (electricity) costs must be high where you live compared to Ontario, Canada where the “all in” price (all taxes fees and surcharges) typically works out to about 17 cents per kWh for a typical household.
  20. Australia's east coast has a "national"grid and our supply can be solar, wind, hydro, coal, gas and our retailer very cleverly divides out the electrons that are renewables and only sells those to us. Our off peak is 26c and peak is 43c balanced by our solar FIT (feed in tariff) of 4.6c. We have producers (generators) suppliers (power lines etc.) and retailers all as separate entities who must all make a profit. This is supposedly much cheaper for the consumer than the old government run entities that used to supply all this at much lower real cost.:) Neo-liberal pour-up economics at work.
