JuiceBox Woes
Discussion in 'Clarity' started by bfd, Apr 4, 2018.
  1. bfd
    bfd Active Member
    For those of you looking at a JuiceBox, I'd offer this cautionary tale… I bought one before Christmas and it worked fine until just a few weeks ago when it lost its way to the router. The support at eMotorwerks has been very helpful, we tried to revive the wifi on the box several ways, with no success. So they sent a replacement unit. I reinstalled the replacement unit only to find that it too can't connect. Not only that, but within two days, it lost its ability to transmit - no blue light at all. I reopened a ticket with eMotorwerks, but I haven't heard from support yet, so I don't know what they'll suggest.
    I work with statistics, so I know it's quite possible to get two bad boxes without it being some kind of indictment of the mfgr as a whole. But it makes me wonder about the build on these boxes. I am hoping they'll send me another one (then I'll have three (!!) since I haven't even had time to return the first box yet).
    So take this for what it's worth. I can say that support (so far) has been responsive and helpful in resolving this, but they can't fix boxes that are coming off the assembly line when they don't work. As always, YMMV.
    Surlycat and Domenick like this.
  2. jdonalds
    At this point I wouldn't recommend the JuiceBox. Shortly after installing our first one it came up with a fault. We sent it back and bought a replacement. The second one too came up with the same fault (ground fault internal to the device), also disconnecting from the WiFi network. That self corrected but now I don't trust it to be working in the future.
    chris davis and Surlycat like this.
  3. Personally, I've heard enough anecdotes about the Juicebox that it's not high on my list of potential EVSEs.
    chris davis and AlanSqB like this.
  4. NeilBlanchard
    NeilBlanchard Active Member
    I have had two, with no problems charging. The older one had an optional wireless unit that required WPS to connect, and I never got that working. But the new Pro40 has been flawless for about 2 years now.
    bfd and Domenick like this.
  5. bfd
    bfd Active Member
    Just received box THREE, and it doesn't work either. Unbelievable.
    Surlycat likes this.
  6. hngo
    hngo New Member
    I have been shopping around for an affordable and reliable level 2 evse in anticipation of the arrival (date unknown yet ) of my Clarity. Have been intrigued by the Juicebox and at one point was top on my list. Hearing about your experience and the fact that out of all the makes of evses, Juicebox is the only brand that I have encountered that sells "refurbished" units on Ebay.
    Thanks for the warning, have scratched off Juicebox from my shortlist.
  7. lorem101
    lorem101 Member
    Does it charge your car or is it only a problem with connecting to WiFi?
    Anystone likes this.
  8. Hobbesgsr
    Hobbesgsr Active Member
    I was dead set on buying a JuiceBox Pro but now I’m looking for alternatives.
    The only other EVSE I know of that has 1) Wifi/Smart App 2) 40A for future needs is the OpenEVSE model. But it doesn’t qualify for the Canadian EVCIP $500 rebate.
    So do I “settle” for the ChargePoint at 32A max?
    AlanSqB likes this.
  9. hngo
    hngo New Member
    Same here. OpenEVSE is tops on my shortlist. It is also portable which is a huge plus if you travel.
    AlanSqB likes this.
  10. Armandy
    Armandy New Member
    When I had my Prius I was looking for a cheap 240-volt charging station, found one at Costco for $599 (Canadian). Installed it a year ago and it has been operating flawlessly so far, not fancy looking or WI-FI capable but I use the timer setting on the vehicle to charge after 7 pm, to 7 am, when rates are .065 cents (Canadian) a kilowatt hour or use the Honda Link to start charging, or key fob to start charging immediately. The charger is also capable of downgrading to amp service should you not have 240 volts available. My installation was easy as I already had a 240-volt socket in the uninsulated part of the garage, just had to run a 240-volt stove cable through the wall and plug it in the welder socket. The GE Duratation also had a lot of room for me to install a kilowatt meter to it so I can keep track of the cost of charging. Not sure if this interest you or not , I think they might be available at Home Depot too. Here is a picture of mine and a link to utube of one.
    Teslawannabe and Domenick like this.
  11. bfd
    bfd Active Member
    While the box sends electricity as expected, without the wifi capability, it's kind of a dumb box. The extra cost for one of these units is to enable wifi capability. so when it's flaky or simply doesn't work out of the box, it doesn't engender confidence for the rest of the components. I can say that support and the company itself seem quite interested in finding out what's going on and fixing it, so at least that piece is in place. I don't know that any of the other EVSEs have a better "track record" as far as QC or "out of the box" experiences go. I hope we can get this one solved - and that the solution then becomes something that they can generalize to the rest of their product line. I get that mass produced items have variance in how they come off the line, but it just shouldn't be so difficult to get a box that works right out of the box. Especially one that retails for well over $500.
  12. ManKo
    ManKo Member
    Could it be a problem specific to compatibility with your WiFi router? It’s hard to imagine 3 units all having WiFi issues. I guess I’m lucky mine has been flawless :)
    NeilBlanchard likes this.
  13. bfd
    bfd Active Member
    If it is, then it is only with the JuiceBox. We have any number of computers (Mac and PC) iPhones, iPads, Ecobee, AppleTV, Refrigerator, several smart TVs and DVD players all running flawlessly on the wifi here. So if the problem is a wifi issue - and it very well could be - it would seem likely to be one that is JuiceBox-centric.
    We've looked at everything from signal strength to WPA/WPA2 issues, to how the network is setup. When all is said and done, the system should work. But so far, it's been sketchy. We'll see what round three brings. Since this newest box seems to be OK in other respects, lights not dimmed out, broadcasting an SSID and supposedly connecting to the home network, charging OK, etc. what it really comes down to is retaining a connection to the network. The wifi router is literally feet away - albeit on the other side of a wall. Still, the signal at the box is plenty strong.
    Domenick likes this.
  14. AlanSqB
    AlanSqB Active Member
    OpenEVSE runs using OpenEnergyMonitor which lets you do some pretty cool things with energy use, solar, etc. https://openenergymonitor.org
    I have a very simple dashboard set up on mine (see below) as I never really had a need for anything more serious. Honestly, the only reason I keep the Wifi module on mine is so I can send it commands when needed (change pilot level, start/stop) via it's built in command page. Even that's pretty rare. Mainly I added the wifi because I wanted to tinker. Mine is DIY so I flashed the HUZZAH wifi board myself and hooked it all up. If I was building another one, and planned to use it portably, I'd probably forgo the LCD screen and the wifi module. They just add too many wires and extra parts that I wouldn't want on a portable unit subject to bumps and shakes.
  15. NeilBlanchard
    Most EVSE units are "dumb boxes". One of the only ones than has WiFi is the Juicebox.
    How far is it from the wifi router to the EVSE location?
  16. Mckersive
    Mckersive New Member
    I will, for data point purposes, chime in here and say that I have no issues with JuiceBox and its connection to my wifi. I have it in the garage where the signal is pretty low. I share in OP's frustration as I am sure he has ripped his hair out trying to make it work.
    I am assuming that OP knows that JuiceBox only supports 2.4GHz and not 5GHz. I don't know if there are WIFI units that only broadcast on 5GHz, but sometimes people set up these 2 bands using different names and this could cause an issue.
    Hobbesgsr and Domenick like this.
  17. Atul Thakkar
    Atul Thakkar Active Member
  18. KentuckyKen
  19. Patrick Chin
    Patrick Chin New Member
    I'm using a Juicebox Pro40 for a week, and so far so good. My nephew has been using same model for about a year, and he hasn't had any issue.
  20. NeilBlanchard
    I did not know that. When did these come out?
