Charger door won't open
Discussion in 'Hyundai Kona Electric' started by KonaTom, Dec 9, 2020.
  1. Keith Smith
    Keith Smith Active Member
    Pin 6... "Gr" Green/red trace maybe?
    hobbit, JoeS and electriceddy like this.
  2. Joey2121
    Joey2121 New Member
    I know it is a low-tech solution but I would be just fine with something like a manual hood release for the charger door. Less to break.
    Tim94549 likes this.
  3. Kona_Ace
    Kona_Ace New Member
    After reading that folks used a plastic pry tool to get the charging door open, I just used my fingers and pried REAL hard to pop the door open on my 2021 Kona Electric Limited. I agree that a manual release for the charging cable, but not the charging door, makes no sense at all! The first time this happened (about a week ago) I had about 14 miles of charge - not enough to get to a dealer. At least this time, I could have made the trip there… Gonna see if the TSB and/or the 81560-K4000 Push Opener replacement can be done to avoid this in the future.
  4. doggyworld
    doggyworld Active Member
    Soo.. just an update.. I think the charging door actually being stuck was related to my 12v battery dying. After I replaced the 12v battery when my car died, I haven't had an issue with the charging door getting stuck anymore.
  5. Kona_Ace
    Kona_Ace New Member
    Lubricated the locking post mechanism and the hinge, as it was inconsistently opening after my overnight charge.
    A few lock/unlock cycles show improvement with silicone lubricant, but time will tell.
  6. Joey2121
    Joey2121 New Member
    Don't have the time to check if it has already been discussed but y'all know there is a manual charger door release under the hood - right? I think you pull up on it. It is located near the 12V battery at the front of the engine bay. Orange knob as I recall.
  7. Kona_Ace
    Kona_Ace New Member
    That release is supposed to be for the charging cable, not the door. And yes, already discussed.
    Appreciate any and all insights into this poorly designed door/locking mechanism.
    Joey2121 likes this.
  8. Joey2121
    Joey2121 New Member
    I haven't tested it. I assumed it would open the door and release the cable. No troubles with the door on our Kona - yet. -knocks on wood-
