Charger door won't open
Discussion in 'Hyundai Kona Electric' started by KonaTom, Dec 9, 2020.
  1. Probably so nobody can open it and smear peanut butter all over your chargeport while you're shopping for groceries ...
    KonaTom likes this.
  3. KonaTom
    KonaTom Well-Known Member
    Wow. Never thought of that one!! As good a reason as any, I guess
  4. ehatch
    ehatch Active Member
    do you have the TSB for the charger door? Mine is already not flush so it gets jammed,and I don't want the poorly designed flap to entirely fall off as I try to break the ice off:D Apparently, there's a campaign for the included L1 charger: 00D36.
  5. Here it is for the port door.
    I don't have a copy of the one for the portable EVSE because it won't apply to my non-Hyundai unit. It's just a stretch-over rubber or plastic cover sort of like what you find on a DVM or other hand tools.
    Several owners have reported that the dealer needs to install it themselves (rather than just provide it to you) which leads me to believe that it's a regulatory compliance issue, such as failing the drop test.
    ehatch and electriceddy like this.
  6. mho and ehatch like this.
  8. ehatch
    It appears to work.EVSyrup didn't drive through freezing rain,plus snow.Why Hyundai can't provide another "campaign" with a gasket fit solution is beyond me.Bolt has a gasket.My concern,if you glue something in,can it be blamed as a "modification" for a laundry list of issues given the TSB for the charge port door already?
  9. Hyundai may have issued a TSB for the benefit of it's dealers and technicians but they never notified customers. How could they blame you for correcting a fault they caused but never disclosed?
  10. KonaTom
    My Kona is fixed now. It took over an hour at the dealers shop. The part came in only three days after they ordered it, so I suspect it is something simply like the pad mentioned earlier. Haven't tested it much yet.
  11. cmwade77
    cmwade77 Active Member
    Well, I had the charge port open while I was getting the car washed the other day, that was a strange one as the doors were locked, so that shouldn't have been possible or so I thought.
  13. ehatch
    Glad you didn't fry your connection to your Li-iono_O
    No driver's dash alert? Mine gives me one if I forget to close the charger door.
  14. cmwade77
    It was closed when I entered the car wash, but the car wash pushed it open. But honestly, considering I have seen videos of fire hoses being turned on open charge ports, I doubt you would fry it even if completely open and the dust protectors were off.
  15. No, of course not. There's a contactor that connects the port to the battery when charging starts.
    Kirk likes this.
  16. Based on comments over at SpeakEV and my own experiments, if you have a problem opening the charge port (unrelated to it being packed with ice) push in the hinge-side corners before trying and you might find it opens a whole lot easier.
    Kirk and KonaTom like this.
  17. I dug up this old thread because YouTuber "The Offroading Mechanic" who appears to work for Hyundai did a short video on why he thinks it sticks. You'll have to open YouTube to view.
  18. hobbit
    hobbit Well-Known Member
  19. I'll see how this goes at keeping water and dust out. 5mm thick closed cell foam.
    Kirk and electriceddy like this.
  20. Looks way better than what I have been using on the lid, and more functional, had to reroute the weather stripping as it wasn't doing the job. Hard to tell by the picture if the foam is round or dimensional also does the door close without undo pressure on the plunger latch and it rotates without resistance?
  21. The polystyrene closed-cell foam is exactly 5m thick and may have been used to hold ICs or such. I just used some sharpened 13.5mm OD tubing to "die-cut" the hole and scissor-cut the outside to a concentric circle. 1/2" copper water pipe might be about right.
    It crushes when the door is closed, you can see that the receptacle on the door fits partly into the recess.
    It's just an experiment, will see how well it holds up.
    Ginginova likes this.
  22. My charge-door would not open and I found this thread and others useful to let me open the door. What worked for me was the trick of: lock doors with fob, unlock doors with fob, then apply a sharp rap on the charge door within 15-sec after doors-unlock. The door then will pop up.
    The Hyun. TSB 20-BD-002H is supposed to fix the problem. It adds 2 vinyl pads to bottom of housing but requires removal of front bumper to get access.
  23. paul hay
    paul hay New Member
    Just had the same problem with my 2018 Ioniq plugin hybrid rang Hyundia and they admitted there was no manual way of opening the door they did suggest holding the lock button on the fob for more than 10 secs and then the unlock button for more than 10 seconds, open the drivers door and quickly try to open the charge door. Worked like a charm I love engineers that know their stuff!!!
    OzKona, Kirby34 and electriceddy like this.
