FloridaSun
Not sure if degradation will change that number.. What seems to happen on Teslas is that they always seem to show the same range but I have seen where the car ran out of battery when the range still showed over 50 miles. I don't think that there is anybody with sufficient miles to have an idea how degradation will show on a Kona. I'd say that the best way to tell if there is degradation if you run your battery down to 1 percent and then charge to 100% and look how many kwh are delivered to the car. Subtract 10% for charging losses (Level 2) and you'll have your remaining battery capacity.It seems your top end buffer is intact, and it will be a good baseline reading to compare to as your battery ages.
