State of Charge - expressed as a percent of maximum capacity of the pack and displayed on the center display.Newbie question what's SOC?
My favorite way to relate to DC fast charging is like filling a cup with water with a fire hose.Obviously a low SOC when you began in the am (my guess is <30%) for the same kWh delivered later at a higher SOC (20 minute difference for same approx accumulation). Not sure what SOC you completed the session upon return, but the rate substantially drops after 74% ish .
https://insideevsforum.com/communit...c-dc-fast-charge-speed.2925/page-2#post-61371
Happy it worked for you.First time using a bc hydro charger and it was painless.
Used the bc hydro app to unlock the combo charger and I’m getting 46 kw charging speed at the superstore in south surrey.
My main concern about long distance travel is the 'up-time' of various chargers. There has to be a better way to confirm/communicate that the charger you want is actually in operation. At the moment one has to charge while there is still enough juice to go to next charger. Makes for many more stops, which should really be unnecessary.Here's an article on the fears about charging that deter EV shoppers, according to Hydro.
It should be noted that the 130 chargers mentioned are mostly Level 2, which are really not useful for long-distance travel unless you can overnight near one.
Basically in my case, try one card, if it doesn't work hopefully the other one doesTalk about unnecessarily confusing things. There are now stations that support one account or the other and it sounds like the association with Greenlots will continue (to the benefit of visitors). In other words, if you have Greenlots and can live without using the listed stations for a while, you won't need a Hydro account after all.
It may be in operation however that doesn't stop something like this from occurring:My main concern about long distance travel is the 'up-time' of various chargers. There has to be a better way to confirm/communicate that the charger you want is actually in operation. At the moment one has to charge while there is still enough juice to go to next charger. Makes for many more stops, which should really be unnecessary.
In the comments, they said it was over Thanksgiving. It looked like there were dozens of chargers, so I would guess the line moved pretty quick.Those might be mostly M3s, as they need an after market adapter to be able to charge on a non-Tesla fast charger. My son had to buy one, $600+, just so he could charge on BC Hydro fast chargers. I suspect most M3 owners wouldn't do that.
Has that charger been rebranded for the Hydro app, or does the app/card now work on the old Greenlots stations?
Took a drive in the sunshine today, to Coquihalla Summit and took a 15 minute charge at Britton Rest Area courtesy of BC Hydro. No card/app needed. 50KW charger, got 43/44 at about 1/2 full.
Darn those winter rocks. Got hit twice but hopefully survived. A few days should tell.
